rear lift blocks
Old May 21, 2008 | 11:24 AM
wmiller's Avatar
wmiller
rear lift blocks
what size blocks do i need to lift my rear about 2"? I know I can use blocks from a 1 ton but what are other options?
Old May 21, 2008 | 12:49 PM
tjbeggs's Avatar
tjbeggs
Factory F-350 blocks (I have some if your interested), after market blocks, add a leaf or and overload (big thick flat spring) add a leaf to the bottom of the spring pack which acts like a block, usually good for 1/2 to 3/4 inch.
With all those options except usually just the standard add a leaf you need longer u-bolts as well. I have blocks, and u-bolts as well that the top overload spring and spacer block if you are interested.
Old May 21, 2008 | 01:03 PM
foxracing0934's Avatar
foxracing0934
Hey Tim, do you have any add-a-leafs for the front by any chance???
Old May 21, 2008 | 01:18 PM
tjbeggs's Avatar
tjbeggs
Nope, sorry
Old May 21, 2008 | 02:08 PM
foxracing0934
Ok thanks anyways.
Old May 21, 2008 | 06:06 PM
FARM69's Avatar
FARM69
Fox, they are pretty cheap. I got mine for $100.
Old May 21, 2008 | 06:41 PM
wmiller's Avatar
wmiller
Tim what do you want for them? Do you have just the overloads or do you also have the perches for them?
Old May 21, 2008 | 06:50 PM
tjbeggs's Avatar
tjbeggs
No perches. I was going to cut them off the frame but decided not to. PM sent on price.
Rick_Fury
Aug 3, 2012 02:00 AM
Rick_Fury
Jul 31, 2012 09:38 AM
R031Kona
Offroad & 4x4
Jun 7, 2008 07:44 AM
78jpa
Jun 22, 2004 12:01 AM
02fidyCrew
May 21, 2004 03:43 PM
