Offroad & 4x4
Rear Lift Blocks
Old Jun 3, 2008 | 10:04 AM
R031Kona's Avatar
R031Kona
Rear Lift Blocks
So I have a 91 Ranger and it has 2 (per side) rear lift blocks. IT CAME THAT WAY, what is the best way to retain my lift and make my truck safer. Suggestions?
Old Jun 3, 2008 | 11:16 AM
captain p4's Avatar
captain p4
The ranger has 2.5" wide spring, correct?
I'd look into a rear shackle flip of some sort, but the SKY Manufacturing piece is made for 3" wide springs. But there is a guy over on fullsizebronco.com selling a different type of shackle flip. I'd try contacting the original poster of this thread and see if he can help you out. That said the other block is probably just a factory wedge block for pinion angle.
Old Jun 3, 2008 | 11:57 AM
75F350's Avatar
75F350
Stock spring hangers can be used for a shackle flip. Just buy a set of front hanger for the rear spring, and hang the shackle from that. They will be the correct width, and will require very little drilling to install.
These are as strong as anything you will ever need.
Upon installation, this should eliminate at least one large block, and at this point you can determine the need for a different all spring pack, or the addition of an AAL.
This hanger will look like this after installation.
Image of rear shackle flip with 64" sping - Photobucket - Video and Image Hosting
Old Jun 3, 2008 | 04:06 PM
quadzjr's Avatar
quadzjr
just another Rockwell looser
add one more lift block.....its the only proper way to do it safely.......
Old Jun 3, 2008 | 06:08 PM
Ryan50hrl's Avatar
Ryan50hrl
or remove both of those...and use 4x4 oak, now make sure its oak as pine or birch will crack, and just cut to length.....
on a serious note.....the shackle flip is your best bet....you could buy lift springs...but they're expensive and don't ride all that well
Old Jun 4, 2008 | 10:50 AM
R031Kona's Avatar
R031Kona
Thanks for the advice , I suspected a shackle flip would be a good start. So would a single lift block would be ok? If the shackle flip do not bring the height back enough?
Old Jun 4, 2008 | 06:02 PM
Ryan50hrl's Avatar
Ryan50hrl
well it depends on the size of it....a six inch block....NO.....but the stock little block....not a problem...
Old Jun 4, 2008 | 06:09 PM
unrulee's Avatar
unrulee
Yeah flip it and add ONE block to taste. Personally no taller than 4".
Old Jun 7, 2008 | 07:44 AM
teds74ford's Avatar
teds74ford
I would recommend trying to get it to the height you want without any blocks. The best thing I did was get rid of mine.
egreco79
Feb 19, 2014 03:00 PM
jleal_21
Dec 29, 2010 09:33 PM
Steve78
Jun 3, 2005 09:14 AM
NewFordOwner
Oct 12, 2004 04:06 PM
86bronco2jeff
Bronco II
Nov 7, 2002 05:29 PM
