TransGo E4OD-HD2-D Install Article
Old Apr 27, 2009 | 07:40 PM
  #46
Izzy351's Avatar
Izzy351
Can't stress enough just following the steps. When I got mine, the directions were VERY intimidating! But as I read them over & over, I pretty much was ready when I cracked open the trans. Having done it, I would do it again in a heart beat. It's WAAAAY more intimidating than difficult. Take your time, do one valve at a time, and make sure they move correctly when you put them back together. That's where the deburring comes into play. You have to make sure the bore doesn't have a bur which will bind the plunger. Assuming you even have to drill. Not all need drilled.
EDIT: Kind of poetic -- "You've got a bur in your bore!"...
Old Jul 12, 2009 | 08:07 AM
  #47
beanhead6D5's Avatar
beanhead6D5
Mike,since its been in for a while now how do you like the Transgo?
Old Jul 12, 2009 | 08:18 AM
  #48
Izzy351's Avatar
Izzy351
I'm not Mike, but I love mine! I would do it again in a heartbeat if I got another PSD.
Old Jul 12, 2009 | 12:46 PM
  #49
Tenn01PSD350's Avatar
Tenn01PSD350
I am Mike. What he said^^^^^^^^^^^
Old Jul 12, 2009 | 03:56 PM
  #50
beanhead6D5
Thanks Mike and not Mike(Joe)!!
I hope to install my in a couple of weeks.
Old Jul 12, 2009 | 03:59 PM
  #51
Izzy351's Avatar
Izzy351
My middle name is Michael -- either works for me. LOL
Old Jul 12, 2009 | 08:09 PM
  #52
trackspeeder's Avatar
trackspeeder
A quick note about the solenoid pack connector. Squeeze the connector and pull up to disconnect it. You will feel the lock on the back connector. Do not use screwdrivers or other instruments of distruction to remove it.
If you break the connector replace it. Just plugging it in without the lock will allow it to work loose. That can lead to a tranny failure.
Old Jul 12, 2009 | 08:19 PM
  #53
F350-6's Avatar
F350-6
Much easier said than done, especially if you have a 4" exhaust.
Old Jul 12, 2009 | 08:25 PM
  #54
Tenn01PSD350
Yeah, I broke mine. Just pushed it back on and so far so good. Kinda held on by gravity but I would feel better if it wasn't FUBAR'd
Old Jul 12, 2009 | 08:55 PM
  #55
beanhead6D5
Note to self! Remove exhaust pipe by tranny when doing the tugger mod.
Old Jul 12, 2009 | 09:15 PM
  #56
Tenn01PSD350
Going tugger are you? At any rate, just take your time.
Old Jul 12, 2009 | 09:31 PM
  #57
mueckster's Avatar
mueckster
I had to pull that plug to remove my trans and didn't have any trouble getting it off the connector. I have the 4'' exhaust and just felt my way around it.
Old Jul 12, 2009 | 11:54 PM
  #58
hucka1a's Avatar
hucka1a
FWIW. I don't know of anyone with a super duty that had to drill the holes in the solenoid pack. I would just skip that part if I had to do it over again.
Old Jul 12, 2009 | 11:59 PM
  #59
Tenn01PSD350
Well, I would agree except that was the nastiest part I pulled down and it needed cleaning.
Old Jul 13, 2009 | 04:00 PM
  #60
trackspeeder
That's the best advise.
