Yes any PSOM will work from 92-97. Where you run into problems is if you replace the whole cluster- if you go that route be sure to get a cluster from the same year as your truck is.
Tim there are minor differences in the wiring among the different years (at least on the gas motors) for the indicator lights. When I put a 92 cluster in my old 95 to see if the PSOM was shot the ABS light stayed light and other lights were screwy also. I assume the same can be said for the PSD's but I'm not 100% on that. Throw your 95 cluster in your 97 and see what happens!
My truck:
92 F150, 4.9, ATI had a melt down on fuse 8 from fuse box in cab to firewall connector melting a few wires.
I purchased a harness out of a 96.
All of my connectors plugged into the 96 harness.
Working:
Speedo and audometer
signals/flashers all lights do work
Not working:
Guages. fuel,volts, oil pressure, temp
radio
AC switch to blower
Washer/wipers
Is this a bad ECM? Possibly burned up
Also if I replace these components, the connectors fit but the color code 92-96 are slightly different in some cases.
