PSOM interchangeability?
Old May 1, 2008 | 10:42 AM
yukonsly's Avatar
yukonsly
I have determined that my PSOM is what is causing my speedo to jump all over the place. I'm trying to source one out....used....rebuilt....etc.....
Will ANY PSOM from 92-97 ford trucks/Bronco fit?
Thanks
Yukonsly
Old May 1, 2008 | 11:34 AM
superduty4x4's Avatar
superduty4x4
Yes any PSOM will work from 92-97. Where you run into problems is if you replace the whole cluster- if you go that route be sure to get a cluster from the same year as your truck is.
Old May 1, 2008 | 08:26 PM
tjbeggs's Avatar
tjbeggs
check out these guys
Electronic Speedometer Service
Chase why do you say you need a cluster from the same year. 94.5 to 97 should all be the same. Do you know of a difference?
BTW I may have a 95 Cluster for sale.....
Old May 2, 2008 | 04:42 PM
superduty4x4
Tim there are minor differences in the wiring among the different years (at least on the gas motors) for the indicator lights. When I put a 92 cluster in my old 95 to see if the PSOM was shot the ABS light stayed light and other lights were screwy also. I assume the same can be said for the PSD's but I'm not 100% on that. Throw your 95 cluster in your 97 and see what happens!
Old May 2, 2008 | 07:29 PM
tjbeggs's Avatar
tjbeggs
Thats alot of work! I will just compare wiring diagrams! I would guess that the 95-95 models are the same but I can't be sure 100%
Old May 2, 2008 | 09:33 PM
superduty4x4
I know it is, I was just ribbing ya.
Old Mar 10, 2022 | 07:44 AM
LeeHD's Avatar
LeeHD
96 harness in 92 150
My truck:
92 F150, 4.9, ATI had a melt down on fuse 8 from fuse box in cab to firewall connector melting a few wires.
I purchased a harness out of a 96.
All of my connectors plugged into the 96 harness.
Working:
Speedo and audometer
signals/flashers all lights do work
Not working:
Guages. fuel,volts, oil pressure, temp
radio
AC switch to blower
Washer/wipers
Is this a bad ECM? Possibly burned up
Also if I replace these components, the connectors fit but the color code 92-96 are slightly different in some cases.
The truck runs and transmission shifts properly.
lee.andrews53@yahoo.com
Big Thank You
Old Mar 10, 2022 | 09:08 AM
LeeHD's Avatar
LeeHD
tnbeggs,
Thake a look at my post on the 92 to 96 harness swap.
I believe the clusters are the same for 95 and 96?
I put a 96 harness in my 92 and some items are not working. Do I need a cluster from a 96?
Old Mar 10, 2022 | 09:26 AM
LeeHD's Avatar
LeeHD
hey superduty4x4 could you respond to my 92 to 96 harness swap above.
Thanks,
Lee
KCTech
Nov 26, 2011 12:11 PM
oldproudvet
Jun 6, 2010 09:24 AM
Josh2021
Feb 21, 2010 08:01 PM
ShamelessMT
51
Jan 28, 2010 03:22 PM
dsh82
May 8, 2003 08:00 AM
