96/97 Instrument cluster problem
Old Jun 6, 2010 | 08:31 AM
oldproudvet's Avatar
oldproudvet
Have any of you guys disassembled the instrument cluster? I've a 97 HD 250 with a speedo only cluster. I picked up a cluster w/a tach but its completely covered, inside and out with dust (gravel road owner). The cluster will bolt in as the wiring is the same, but this cluster has issues. I've got the plexiglass cover off, exposing the gauges, but need to access the speedo 'cuz the odometer trip button doesn't work. Do I have to pull off the gauge needles to get inside? I'm not sure that's a good idea because you could lose the gauge calibration. Or at least you'd lose it with older gauges, I'm not sure about the newer electronic ones. Thanks
Old Jun 6, 2010 | 09:24 AM
96ford250's Avatar
96ford250
i just did that swap last week and you just pull out the guages on the out side to get to the one in the middle pull them straight up there held in with little studs that are used to make the electical connections
93nighthawk
Aerostar
39
Sep 23, 2015 08:55 PM
12valveEx
Aug 2, 2015 08:07 PM
Shadowrider123
Nov 15, 2014 09:18 PM
tjcprop
2004 - 2008 F150
Apr 18, 2014 06:59 AM
PRL
Jul 14, 2010 08:57 PM
