overhead computer died
Old Apr 27, 2008 | 07:43 AM
fabrijack's Avatar
fabrijack
anyone know where I can get a replacement computer for my overhead console? Does any other vehicle computer fit? Is the computer model specific? Everything I look up online has different buttons than mine. 2000x with 7.3
Thanks,
Jack
Old Apr 28, 2008 | 03:53 PM
Capt Dan's Avatar
Capt Dan
Did the display go out? If so, there is a fix. it is just some loose diodes/chips. I'll try and search for a link.
found it.
Old Apr 29, 2008 | 04:08 PM
fabrijack's Avatar
fabrijack
yes the display went dim then out completely. I'll try these ideas and see if I can fix it before I spend $175 on a new one!!
Thank You for the help.
Jack
Old Apr 30, 2008 | 10:18 PM
fabrijack's Avatar
fabrijack
It took two tries to get everything soldered but this fixed it perfectly!
Thank you so much, saved me a fortune and I was having withdrawals not knowing what the outside temp was.
Jack
Old May 1, 2008 | 08:15 AM
Downriver Thunder's Avatar
Downriver Thunder
Mine periodically goes out. It just takes a good smack to get it going again.
Old May 1, 2008 | 03:57 PM
fabrijack's Avatar
fabrijack
probably has loose chips like mine did, follow the link in the post above and re-solder the chips. Mine is brighter than it has been in 2 years..
Old Nov 18, 2008 | 08:20 AM
ssolid's Avatar
ssolid
I just did the fix to my overhead console computer last night...Radios Shack 15w soldering iron and some .015 silver solder..$15...soldered one 680 chip that was loose on one end and bang...works like a champ...thanks for all the help from this board.
Old Nov 18, 2008 | 08:29 AM
JaySVX's Avatar
JaySVX
My compass doesn't work, but my miles to empty does. Still, I never use that, I like the analog indicator on my instrument panel.
Baradium
Jun 3, 2017 09:45 PM
Danj2718
Mar 31, 2017 01:50 PM
Hadden117
Feb 2, 2017 02:13 PM
javracer
Jan 12, 2016 01:33 PM
eldorado73
Dec 20, 2010 12:52 PM
