Overhead trip computer
Old Mar 11, 2017 | 10:54 AM
Danj2718's Avatar
Danj2718
4wd Low
Greeting. I'm a new member and have just purchased a really nice 2005 Excursion. The only thing that is not working is the little overhead electronic trip computer (Miles to empty; mileage, etc). The display is blank and I can't get it to turn on. Anybody have that issue? If so, what's the best way to approach fixing it? Thanks in advance.
Old Mar 11, 2017 | 11:21 AM
Misky6.0's Avatar
Misky6.0
The most frequent issue is the resistors on the circuit board de-solder themselves from the heat from the roof. Remove the over head console (1 screw in the glass compartment, then you pull down snugly on the rear, then it'll hang down so you can remove the wire connectors.
Old Mar 11, 2017 | 11:40 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Then send it to CircuitBoardMedics and have them fix those resistors and anything else they find while inside it. Unless you are super handy with a soldering iron and tiny circuit board parts...
Old Mar 11, 2017 | 11:41 AM
agsmv1's Avatar
agsmv1
I used the ebay guy in Florida. Works like a champ and the MPG is actually pretty darn close to my calculated MPG.
Old Mar 11, 2017 | 11:43 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Originally Posted by agsmv1
...the MPG is actually pretty darn close to my calculated MPG.
Same here after getting mine refurbished by CBM. Cost me about $50.
Old Mar 11, 2017 | 11:45 AM
dualwheels66's Avatar
dualwheels66
I had the same issue on my '05, took it apart only to find that 4 of the resistors were broke in half. I found a guy on eBay that repaired it for $20. I sent it to him on a Friday and got it back the following Thursday. I think it was automotive circuit solutions, or something like that. Just go on eBay and search, excursion overhead console.
Old Mar 11, 2017 | 11:50 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I would just add that CircuitBoardMedics are a sponsor on this site...
...and they did great work for me. They didn't just fix the resistors. They went through and resoldered anything that was suspect.
Old Mar 11, 2017 | 02:18 PM
Stewart_H's Avatar
Stewart_H
I have the how-to for fixing this linked in the tech folder.
Stewart
Old Mar 11, 2017 | 06:08 PM
RBerry9511's Avatar
RBerry9511
Soldering it yourself is pretty darn easy. I just did this about a month ago. I waited so long because I was apprehensive about doing it but it was very easy. Give it a try and if you screw it up then you can send it to one of the places recommended.
Old Mar 12, 2017 | 11:21 PM
jda407's Avatar
jda407
Trailering
noob question... where is the tech folder?
Old Mar 13, 2017 | 01:09 AM
Stewart_H's Avatar
Stewart_H
It's one of the "Read First" sticky threads which are "stuck" at the top of the thread listing page.
Stewart
Old Mar 13, 2017 | 01:55 PM
Greenscobie86's Avatar
Greenscobie86
Did this myself with a huge soldering iron that wasn't meant for the job, very easy.
Old Mar 30, 2017 | 09:51 PM
kev03's Avatar
kev03
I did this myself and turned the board over where the four resisters are heat the solder up and helps lock them in place, but make sure you use something to hold them in place.
Old Mar 31, 2017 | 07:08 AM
Watcher58's Avatar
Watcher58
I'll add in that when you take the board and look at it, there may be nothing obviously loose. Just take an electronic soldering iron with a fine tip(Radio Shack, Home Depot, Amazon) and touch the connectors for those chips (on the back side of the board) You can see the circuits easily from the back of the board. Don't get carried away with solder if you have to add some. Also use the very thin electronics solder. After all that, just take the module back to the X and plug in to see if it works before you put everything back in.
Old Mar 31, 2017 | 01:50 PM
Romanova's Avatar
Romanova
Same, best $20 I ever spent.
Paul Titus
Oct 17, 2014 12:02 PM
totavikid
Nov 1, 2007 04:08 PM
tomsen5
Jul 24, 2007 10:53 AM
LCinNC
Jun 10, 2004 04:01 PM
