** Overhead Trip Computer Install Tips **
Old Oct 14, 2008 | 12:14 PM
Hadden117's Avatar
Hadden117
Well I am a newbie here and own a 2003 XLT Excursion. I popped open the overhead console to find a wiring harness in the location where a trip computer would be. Any thoughts?? Can I just buy a trip computer from a junkyard or dealer, plug it in and go? Or are there other mods that I need to do to make this work properly? Thanks in advance.....
Old Oct 14, 2008 | 01:15 PM
Monsta's Avatar
Monsta
Sit. Stay.
You won't have the outside temp. You need the sensor for that. It mounts on the front of the radiator on the driver's side. Mine has the wire harness for it even though I don't have the trip computer either. You might want to check the front of yours to see if you have the harness for that sensor.
Other than that you should be good to go.
Old Jan 29, 2017 | 04:03 PM
03PowerstrokeExcurs's Avatar
03PowerstrokeExcurs
Does anyone know if an 01 trip computer works with an 03 X? The connector is the same although I would have to flip it around...the wire colors look different too.
Old Jan 29, 2017 | 10:06 PM
Misky6.0's Avatar
Misky6.0
If you have the auto temp (digital) a/c system the external temp is display there - not in the overhead.
Old Jan 31, 2017 | 11:49 AM
jpankask's Avatar
jpankask
I have used a trip computer from what I believe was from 00/01 in my 04 limited. It works fine for the mileage/miles to empty indicator.
Old Feb 1, 2017 | 05:35 PM
03PowerstrokeExcurs
Thanks I'll try it!
Old Feb 2, 2017 | 02:13 PM
brian42's Avatar
brian42
Veteran: Navy
There was a major electrical/wiring change after 2001 so some things may work and others may not regardless of wire colors (if the connectors are the same) starting with 2002 trucks.
RUNVS
Feb 26, 2020 04:06 AM
dkkids5
Feb 19, 2018 03:35 PM
Baradium
Jun 3, 2017 09:45 PM
Danj2718
Mar 31, 2017 01:50 PM
Russell2004
Apr 1, 2016 02:28 AM
