overhead console
Old Jun 23, 2008 | 03:52 AM
topdog5's Avatar
topdog5
Smile overhead console
hi guys, got a small problem I have to take down my overhead console to fix my compass and mpg readout message center it was not working when i got the truck so i am going to fix it my self. but dont know how to get at it yet my overhead has a/c controles ***** on it I am not sure what to do first on this tear down if some one tell how me to get the console down and the message center out maybe i can find somebody fix it or maybe i can try just dont know what to do first help please !!!!
Old Jun 23, 2008 | 04:48 AM
Monsta's Avatar
Monsta
Sit. Stay.
Reach up and pull it down. It is just held on by push-fit clips.
Old Jun 23, 2008 | 11:25 AM
topdog5's Avatar
topdog5
do these overheads have any scews in them
Old Jun 23, 2008 | 02:05 PM
CalEx4x4's Avatar
CalEx4x4
Yes, one screw holds the overhead console
Yes, there is one screw under one of the two flip down doors (for the garage door opener, or the sunglass holder). It will pull down with a few quick tugs on the front and back. You might use a small bungee cord afterwards to
hold the console without placing too much tension on the wiring. There are just a few wiring connectors to unclip, and the console will drop down easily.
There are no push-pull cables like in the "old days" for the AC/heater controls. I've had to replace the "lie-o-meter" as they call it on my 2003.
Although mine is pretty accurate, so I didn't hesitate to get a replacement. Found it right here on this forum from one of the other members. There is a fix mentioned if you do a forum search, just didn't work for my issue.
Good luck.
George
Old Jun 24, 2008 | 05:19 AM
Monsta's Avatar
Monsta
Sit. Stay.
No, one screw DOESN'T hold the console. The front has those push-fit clips, while the back has a piece of plastic that goes into a guide. Pull down the front and it slides forward a tad to come out of the guide. Unplug the connectors and "Bob's your Uncle". The thing only weighs about a pound (maybe). It will not put any undue stress on the wiring if you let it hang.
Okay...on edit... this is how it was on my 2000 and my current 05. Maybe they changed something in the middle years.
Old Jun 24, 2008 | 07:45 AM
jpankask's Avatar
jpankask
My 2002 does have a screw. It is under the rear flip-down door.
Old Jun 24, 2008 | 12:24 PM
Downriver Thunder's Avatar
Downriver Thunder
I took mine apart yesterday to find a black spot on the LCD glass. Guess mine is burned.
Old Jun 24, 2008 | 12:40 PM
Downriver Thunder
I found the repair and will try it. I didn't know this spot was normal.
Old Jun 25, 2008 | 06:25 AM
Downriver Thunder
That fix is right on the money! I took mine apart and found 3 of the chips broke loose. Soldered them back on and it's working again.
Old Jun 25, 2008 | 05:03 PM
topdog5's Avatar
topdog5
Hi guys thanks for all the help on the fix on my overhead what all do you take apart to get to chips you are talking about soldered. I also find I place on ebay where you can send your unit to him and he will repair it better than it was he will do it for 85 dolllars or so he says first i am going to try to fix my unit. thank for your help
Old Nov 18, 2008 | 08:19 AM
ssolid's Avatar
ssolid
I just did the fix to my overhead console computer last night...Radios Shack 15w soldering iron and some .015 silver solder..$15...soldered one 680 chip that was loose on one end and bang...works like a champ...thanks for all the help from this board.
Old Nov 18, 2008 | 10:16 AM
crum71's Avatar
crum71
1/8 mile Oval Track
Do you have this guys name on Ebay? I tried doing mine,and I just gave up on it.
