Dash board broken?
Old Apr 26, 2008 | 01:31 PM
  #46
quicklook2's Avatar
quicklook2
you need a rivet tool.
any hardware store has one.
Old Apr 26, 2008 | 06:47 PM
  #47
Pearlwhite94's Avatar
Pearlwhite94
Ok so i got the dash bracket installed and was excited to go test it over some road bumps but when i tried to start it, it wouldnt. THe fuel switch works cause it measures the fuel in each tank but when i turn the key it doesnt make the sound of the fuel pump working. Any ideas on what i could have damaged??
Old Apr 26, 2008 | 08:14 PM
  #48
quicklook2's Avatar
quicklook2
you tripped the fuel shutoff switch.
it is behind the pass kick panel where you were working.
Old Apr 26, 2008 | 09:24 PM
  #49
quicklook2's Avatar
quicklook2
you did take the kick panel off to do the repair, right?
Old Apr 28, 2008 | 09:28 AM
  #50
Pearlwhite94
Yea i my guess was the switch too i just didnt know were it was, its all fixed now. I followed the directions to keep me from breaking things so i removed both kick panels, all the screws to the dash. Top ones, loosen some by e- brake, and one under passenger side. Pull dash back gently, and put a 2x4 to keep it in place. I didnt want to risk braking dash parts so i removed my door to get into the area. Went ahead and replaced door hinges that were sagging real bad. THe pins and bushings i mean. It doesnt take long if you know your way around a truck, i imagine if its your first time you may struggle some with the bracket. I also had to buy a rivet tool so the repair cost me quiet a bit but it was so worth it, it worked perfectly. I have the instructions at hand so if anyone needs anything il be glad to help!
Old Apr 28, 2008 | 09:57 AM
  #51
quicklook2's Avatar
quicklook2
all that to fix the dash! WOW!
Old Apr 28, 2008 | 11:54 AM
  #52
Pearlwhite94
I guess it varies with each situation, i was needing to repair my door hinges too so i went ahead and did that too. It acctualy didnt take very long at all. it sounds like alot of work but its not.
Old Apr 28, 2008 | 12:35 PM
  #53
quicklook2's Avatar
quicklook2
i was just laughing with you.
glad you got stuff fixed.
Old Apr 28, 2008 | 01:07 PM
  #54
gtinswva's Avatar
gtinswva
Jeez, now I guess I have to fix my dashboard after reading this thread. Thought I could just ignore the rattle but now that I know how easy it is...
Good thread, thanks guys.
stephen1151
1978 - 1996 Big Bronco
Nov 10, 2014 06:42 PM
GuitarJesus
Oct 4, 2014 10:48 PM
climat
15
Aug 24, 2008 10:10 AM
Supercouper
Jul 8, 2008 05:55 PM
RotGrubestier44
Jan 28, 2006 07:33 PM
