Broken fuel tank selector switch
Old Jul 6, 2008 | 04:16 PM
Supercouper's Avatar
Supercouper
I broke my tank selector switch it's now pushed into the dash to where I can't see it. Anyone had this problem?
Old Jul 6, 2008 | 09:01 PM
60F100's Avatar
60F100
I have a 92 with the switch mount broken. You can remove the dash part, disconnect the switch, pull the wires thru the hole and reconnect the switch letting the switch hang on the outside of the dash. This way you can use it until you can find a new dash. You can try to glue it but I haven't had much luck gluing plastic parts together where any kind of strength is needed.
Old Jul 7, 2008 | 12:54 PM
Maniac's Avatar
Maniac
I used some of that epoxy that begins clay like with two colors. It has worked for over a year.
Old Jul 7, 2008 | 01:05 PM
wintremute's Avatar
wintremute
walmart sells an epoxy called plastic welder that I have used with good results.
Old Jul 8, 2008 | 05:55 PM
donnor's Avatar
donnor
Fuel tank selector switch mount fixes...
These tabs on one of my vehicles broke some time back. I fixed it with a small dab of PVC/ABS/CPVC cement judiciously and sparingly applied to the back edges of the switch and the dash. (The screw attachment points had pretty well disintegrated).
I also used "Magnum Steel" 2-part epoxy to recreate the screw attachment points on another. Both fixes have worked well so take your pick! The latter may be better in that it is easier to replace the switch at a later time should the need arise.
dn.
mikeceli
28
Aug 8, 2022 08:55 AM
Erictusio
Feb 13, 2017 12:58 AM
texasblue55
Jan 29, 2016 02:08 PM
87beater
16
Sep 13, 2011 06:42 PM
camperspecial1979
Jun 21, 2009 12:57 PM
