Broken Dash Mount!!!
Old Jan 28, 2006 | 03:14 AM
RotGrubestier44's Avatar
RotGrubestier44
The passenger side dashboard mount in my 94 F-150 XL has broken/come loose. I know this is a common problem. What is a common solution? Replace it? But how? What exactly needs to be done here? Any and all help is much appriciated.
Old Jan 28, 2006 | 06:53 AM
frederic's Avatar
frederic
There's a kit from ford to fix it.... or you can screw a flat metal strip to the dash, and then to the hole in the door pillar where the dash used to attach to.
Old Jan 28, 2006 | 08:13 AM
subford's Avatar
subford
From FORD you get one steel, double angle bracket, three pop rivets, and a set of installation instructions all in a box.
Yes they did have to order it and it cost $18.72 plus Tax for a total of 20.09 as of 11/04/05.
Took about two days to get it and with out this number they did not know what I saw talking about. Part # F4TZ-1504366-A
Also see POST:
https://www.ford-trucks.com/forums/s...d.php?t=446589
Old Jan 28, 2006 | 09:22 AM
TexasGuy001's Avatar
TexasGuy001
I just installed Ford's kit. It went for a little over $20 It worked great. I would advise using one of the "snake" type drill adapters to drill the holes for the rivets. That's what I did. This way the dash doesn't have to come out as far. The way it is described in the instructions, I would have never been able to drill the 3 holes by just using a drill. If you have the "snake" deal for a electric screw driver, it will work if you can find a drill bit with the hexagonal base. If you don't have one, you can get one at WalMart for about 6 bucks.
Old Jan 28, 2006 | 07:33 PM
RotGrubestier44
Thanks for the help guys. I should be doing this in a few weeks hopefully, so we'll see how it goes. It sounds easy enough.
Justin73supercamper
Nov 30, 2016 08:16 PM
dasbulliwagen
Sep 19, 2015 04:41 PM
GuitarJesus
Nov 7, 2013 07:36 PM
64F260
15
Jan 22, 2010 07:23 PM
jbullfrog
Mar 28, 2008 09:13 AM
