Dash board broken?
Old Apr 22, 2008 | 04:08 PM
  #31
alz's Avatar
alz
Yes, if it is still available.
Old Apr 22, 2008 | 04:10 PM
  #32
Pearlwhite94's Avatar
Pearlwhite94
oh il go check! Thanks alot man if its still available you just made my day!!!
Old Apr 22, 2008 | 04:19 PM
  #33
quicklook2's Avatar
quicklook2
Originally Posted by Pearlwhite94
im lost completely. Im sure a diagram would help but i understand if ur just about done with patience.
this really is a simple thing to fix.
once you get it apart it is pretty obvious how to use screen/epoxy.
good luck.
Old Apr 22, 2008 | 07:26 PM
  #34
Pearlwhite94
i called around the dealerships and one does have it available for 14 dollars so thats were im going. Thanks to all of you for your help on this and for the patience you had with me!!!
Old Apr 22, 2008 | 08:01 PM
  #35
quicklook2's Avatar
quicklook2
post a pic of the instructions and parts in the kit after you pick it up.
Old Apr 22, 2008 | 08:24 PM
  #36
JumpingJerry's Avatar
JumpingJerry
glad I saw this post. My dash is broken too. Time to get to work fixing it.
Old Apr 22, 2008 | 08:54 PM
  #37
Pearlwhite94
Yea ima do that, im going to post pics and the info with it cause i struggled quiet a bit to find this thing.
Old Apr 22, 2008 | 10:06 PM
  #38
crestfallinman's Avatar
crestfallinman
all u need is a small piece of aluminum
i bent it on a 90 degree angle, put 2 holes in it and bolted it onto the original hole and a screw into the dash
it works amazingly if thats a word
Old Apr 22, 2008 | 10:22 PM
  #39
Pearlwhite94
******** type="text/javascript"> var uUrl = "myspace.com/asaucedo05"; var uHref = "http://www.myspace.com/asaucedo05"; document.write(""); if(uUrl.length>24){ document.write(""); document.write(uUrl.substring(0,24) + "..."); document.write(""); document.write("" + uUrl + ""); }else{ document.write(""); document.write(uUrl); document.write(""); } document.write(""); *********>MySpace.com - www.myspace.com/34048900 look at my pics i have one of my truck!
Old Apr 23, 2008 | 07:02 AM
  #40
TexasGuy001's Avatar
TexasGuy001
I'm glad you found one! Post back with the part number. I think it would help others.
I would definitely use the rivets, since small screws would likely pull through the thin plastic and strip out. Also, it looks like screws with washers or small bolts would not clear when putting the dash back into position.
Be sure to smooth off the remaining broken plastic so that the bracket will sit correctly. You can use a dremel, file, or sand paper. Or a combination of those.
You can also do what crestfallenman suggested. Several people have done that. It works well.
Old Apr 23, 2008 | 08:38 AM
  #41
Pearlwhite94
The part number is f4tz-1504366-a someone else posted it earlier. I probably could get it fixed without the bracket but i need detailed instructions and atleast the bracket comes with those. Il post pics as soon as i go out nad buy the bracket.
Old Apr 23, 2008 | 01:49 PM
  #42
Andy63's Avatar
Andy63
The thinkfordpartsguy website from here lists the part for $13.15
Old Apr 24, 2008 | 12:13 PM
  #43
tobyw's Avatar
tobyw
Wow... $13.15 for the kit, but another $9.50 to ship and thats just to the other side of the state!!! I'll definetly be coming up with my own fix.
Old Apr 24, 2008 | 01:19 PM
  #44
Andy63's Avatar
Andy63
I ordered one. Comes right to my house. Do not have to spend time on the phone with a bunch of dealerships, do not have to try to get to the dealership that has it in rush hour traffic since there parts departments have bankers hours and I work 9 hour days. I know everbody does not like to pay for shipping. How much is driving around (cheapsest gas currently 3.51 gallon) and your time that could be better spent consuming cold beverages or hunting for parts at Carlisle worth?
Andy63
Old Apr 26, 2008 | 01:10 PM
  #45
Pearlwhite94
ok i got the kit, then i realised............how the hell do i install rivets???? THe instructions show a tool used but doesnt say what it is. Any one have any idea what i can do? I drove to the dealership only to find out it was the last one and i guess the reason it cost me 30 bucks..................sigh!
