Sponsored by: Real Truck
Help with trany ideas, Please!
Old Mar 24, 2008 | 10:50 AM
firefighter1204's Avatar
firefighter1204
I have a 2001 F250 7.3 trany rebuilt with 23,000 miles by dealership. New torque converter at 64,000 by dealership at my cost, $3,000. Now trany is leaking again. I was told it may need a new torque converter again. I read in here where my truck has a Mechanical diode that is probably causing the problem. What do I need to do to keep this diode from causing more problems and what do you recommend to replace my torque converter with. Should I put in a tugger? I want it fixed and do not want any more problems. What all do I need to do?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Mar 24, 2008 | 12:58 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
When the trans was rebuilt they should have replaced the mechanical diode with a sprag type one way clutch.
Even if they didn't, the mechanical diode doesn't cause leaks. What exactly is your truck doing?
Old Mar 24, 2008 | 01:13 PM
firefighter1204
After driving more than 40 miles on a hot day 70+ it leaks trany fluid out from the inspection plate. Stopps after the truck cools down.
Old Mar 24, 2008 | 01:17 PM
msgtg's Avatar
msgtg
If it's coming from the inspection plate, is there a gasket involved?
Joe
Old Mar 24, 2008 | 01:32 PM
firefighter1204
Thought that it may be a front seal on the transmition. Mech. said it may need a new t/c and pump kit. also cut old filter in half and found metal.
Old Mar 24, 2008 | 03:50 PM
suzuki0702's Avatar
suzuki0702
input shaft seal ? is the tranny acting up other than that?
Old Mar 24, 2008 | 05:26 PM
firefighter1204
no, working fine other than leaking when it heats up. I think that it heating up to fast. May be more than just a seal.
Old Mar 25, 2008 | 01:19 AM
aldridgec's Avatar
aldridgec
There is an updated front seal for the transmission because of the weeping problem. Repeated failures exisited on the old style seal. I believe the new one is brown and the old one is gray but don't quote me. Need to make sure the updated seal is in place. Unless the converter is cracked, it shouldn't leak.
epdukes13
Jul 28, 2012 12:33 PM
Khart
15
May 3, 2009 09:02 PM
kl67
Feb 14, 2007 05:14 AM
Myckel
Apr 19, 2006 09:01 AM
hokie
Apr 8, 2005 10:16 AM
