That's what I'm guessing!<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o> <o> </o> When I take off or switching to second or third, after releasing the clutch is ok but, if I give it more gas/higher RPM's it seen as if the clutch engages itself, as if giving it too much gas and holding in the clutch midway, RPM's rev high but won’t go anywhere. I have no problem changing gears. I'm guessing poor hydraulic fluid. <o></o> <o> </o> What’s the best way to replace the fluid?<o></o>
<o></o> 87’ F-150<o></o> 5 Lt/302 ci<o></o> 4 speed trany w/ granny gear (only use three gears)<o></o> Hydraulic clutch <o></o>
It sounds like it's slipping and needs a new clutch. A hydraulic problem would do the opposite and it would stay engaged and cause shifting problems. My suggestion would be replace Clutch, Throwout Bearing, and Slave Cylinder, and bleed the system.
classic symptoms of a worn clutch disc. You'll probably be surprised how much better it feels after replacement.
If yours has a pilot bearing, replace that in addition to the t/o bearing.
