what carb is this ?
Old Mar 24, 2008 | 03:54 AM
camaroneil's Avatar
camaroneil
what carb is this ?
my truck is a 1963
it has a 223 straight 6
couple of questions
the valve cover only has 2 bolts on the top, does this mean it's an earlier engine?
also, it has a brand new carter carb fitted but i think it's the wrong one,
the numbers on it are:
0 1736 (i think)
model RBS
on the side of the base it has a funny symbol then 8A3765
thanks,
neil
Old Mar 24, 2008 | 04:09 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by camaroneil
my truck is a 1963 it has a 223 straight 6
couple of questions. the valve cover only has 2 bolts on the top, does this mean it's an earlier engine?
also, it has a brand new carb fitted but i think it's the wrong one,
the numbers on it are: 0 1736 (i think) / model RBS on the side of the base it has a funny symbol then 8A3765
thanks,
neil
The valve cover is the same from 1952 thru 1959, and was used on both the 215 and 223 engines.
The 223 head is the same from 1954 thru 1959. The head and valve cover changed in 1960.
It's possible only the head has been changed, not the entire engine.
The original carburetor would have been either a Holley 1V or a Ford 1V.
What you carb is...I don't know, the numbers from the carb you posted don't appear in the truck parts catalogs. A picture might help ID it.
Old Mar 24, 2008 | 04:18 AM
camaroneil's Avatar
camaroneil
thanks for the quick reply,
it's a carter RBS carb,
as for the engine,
i'd like to find out more about it,
48 E 2
EBP-6015-E
tell me what other numbers to find on it,
many thanks,
neil
Old Mar 24, 2008 | 05:21 AM
NumberDummy
as for the engine,
48 E 2
EBP-6015-E
many thanks,
neil
Carter carbs of this vintage were used on many trucks.
The 1961/67 Econoline's with 170 engines used a Carter 1V, as did 1968/72 Econolines & F100/350's with 240 or 300 I-6's.
I still couldn't find any refs for the numbers you posted in the Ford parts catalogs.
Studebaker used Carter RBS carbs, but I couldn't find those RBS numbers in my Studebaker parts catalogs, either.
EBP-6015-E = The bare block casting number used on 1954/59 223's.
Is your truck RHD?
Trucks sold in the UK, Europe and elsewhere may not use the same vintage engines that were used in the US and Canada.
Old Mar 24, 2008 | 05:27 AM
camaroneil's Avatar
camaroneil
many thanks numberdummy,
at least i know what engine i have in,
just need to try and get the relevant parts to put it back to column change now, i can't find the actual lever/rod listed anywhere, (the bit that goes into the collar on the steering column),
all i can find is the collar and the ****,
thanks again for the info,
neil
Old Mar 24, 2008 | 05:31 AM
NumberDummy
all i can find is the collar and the ****, SEE BELOW
thanks again for the info, neil
I edited (as usual), see the last couple of sentences in post above.
EDIT: FTE sponsor GREEN SALES (greensalescompany.com) has ONE new original shift lever.
C4TZ7210J .. Shift Lever / Fits 1961/64 F100/250 2WD with a 3 speed manual transmission.
Old Mar 24, 2008 | 05:49 AM
camaroneil's Avatar
camaroneil
it's LHD,
only came here a few years ago from alabama,
i'll have a look at green sales,
thanks, yet again,
neil
K9sicem
Dec 27, 2013 07:33 PM
75Three90
Dec 18, 2013 12:10 AM
chamblizi
1978 - 1996 Big Bronco
32
May 12, 2012 06:18 AM
alex severson
Feb 21, 2011 09:13 PM
red68
20
Sep 27, 2004 11:42 AM
