carb spacers??????
Old Sep 9, 2004 | 09:16 AM
red68's Avatar
red68
carb spacers??????
i was thinking of adding a carb spacer to the f150 4x4, it has the stock cam w/ edl. proformer intake, w/ 600cfm edl. carb. i'm looking for more low end. and i heard a carb spacer will help. but, a 1" or 2"??????? the truck has a 351m, at. stock gears, w/ 31 x 10.5 on it. any ad vice will be great!!! thanks!!
Old Sep 9, 2004 | 01:17 PM
beartracks's Avatar
beartracks
Be sure to use a four hole spacer. An open one will ruin your bottom end. Try a 1" and let us know what it does. That's what I run.
Old Sep 9, 2004 | 01:54 PM
jwtaylor's Avatar
jwtaylor
IMO, At $25+/- its worth trying a 1" four hole spacer as beartracks mentioned. later
Old Sep 9, 2004 | 03:06 PM
ranchero77's Avatar
ranchero77
how would you like to customize your own spacer. check this out.
http://performanceunlimited.com/cobr.../governor.html
Old Sep 9, 2004 | 03:11 PM
jwtaylor's Avatar
jwtaylor
Thats pretty cool....can't say I have seen one of those before....$90..+...$40 for additional inserts....ouch...still interesting though. Are you using that product ranchero77?
Old Sep 9, 2004 | 03:25 PM
ranchero77's Avatar
ranchero77
its a recent find. but haven't tried it.
I did however divide an open 1" thick spacer which seemed to help. I was on that topic a couple of months back.
Old Sep 10, 2004 | 07:44 AM
jwtaylor's Avatar
jwtaylor
How did you go about dividing the spacer?
Old Sep 10, 2004 | 03:49 PM
ranchero77's Avatar
ranchero77
after transfering the location of intake divider to the spacer I just milled out a slot 1/8 wide x 1/4" deep into each the side of the spacer and cut a peice of aluminum to fit. a little dab of silicon in the slot to seal it. nothing to it.
if don't have a mill maybe you could use a coping saw. that would fit inside the spacer.
Old Sep 10, 2004 | 05:09 PM
jwtaylor's Avatar
jwtaylor
I see........later
Old Sep 10, 2004 | 06:19 PM
stevef100s's Avatar
stevef100s
A buddy of mine had me make him a 4 hole carb spacer out of hard maple. He says it works great, and doesn't transmit the heat from the intake to the carb. I wonder if I could sell them?
Old Sep 10, 2004 | 06:28 PM
jwtaylor's Avatar
jwtaylor
Actually I was gonna mention that...some are made of wood...if a person had some time they could make out a few blanks and play around with designs.
Go for it....if you can sell'em for $25 or so and make it worth your time and energy go for it.
Old Sep 11, 2004 | 07:38 AM
71swissaqua's Avatar
71swissaqua
I'm a woodworker by trade and have made several spacers in the past. in my opinion the maple ones tended to crack around the ears. i think a Baltic birch plywood one would be better.
Clint
Old Sep 11, 2004 | 07:50 AM
fordsrgrt's Avatar
fordsrgrt
if you should buy or use one get a phenolic one they wont transfer heat the way a metal one will. which in turn keeps the carb cooler.when i got mine last year from schucks out here it came with an insert to either keep it open or put in the other insert with the holes .wasnt very much if i recall
Old Sep 13, 2004 | 08:54 AM
ranchero77's Avatar
ranchero77
some time a go I started making one out of 1 1/2" clear acylic. I thought it would be cool to see the gas going into the intake.
I have a detailed drawing of a square bore spacer if anyone was wanting to make their own.
Old Sep 15, 2004 | 06:25 PM
460me's Avatar
460me
I got a 2" one for my 79,hard to tell if it did any good.But yeah it well help keep the carb cooler longer.On one of the truck/car/speed show's,the guy was saying that it fakes the manfi. out,making it think the manfi is bigger.
