questions about rebuilting a fe?
Add to prev post: By using the 390 crank, rods, pistons, you solve the "sunken piston" and compression ratio problems of the 360. Trying to find high CR 360 pistons seems to be hard to do, according to others on this site.
Other variables will determine final CR. (actual piston used, heads, head work)
I got a C4AE-B 390 crank (10/10) and a set of 390 rods setting in the shed if you want to make things easy on yourself. You'll have to get pistons for the build though. All mine are std.. You might have to hunt down 1 extra rod as one's small end is worn OofR but that isn't that big a task. Your local it would seem, OC so it might save me the trouble ebaying the chit off ...PM me if interested.
YoungMT Hick
08-21-2011 05:44 PM
460man
15
11-11-2005 12:38 PM
freejay
05-02-2003 08:52 AM
75explorerxlt
24
04-30-2002 07:09 PM
