360/390 questions
Old Nov 9, 2005 | 09:04 AM
460man's Avatar
460man
360/390 questions
i have a 360 currently. i also have 390 heads, pistons, and i think rods. also high rise intakes. what can i do to the 360 with the 390 parts to make it bad a@@
Old Nov 9, 2005 | 09:50 AM
Mike G's Avatar
Mike G
You need at least the 390 crank, then you have the goodies to make a nice 390 or better.
Welcome aboard! --Mike
Old Nov 9, 2005 | 09:53 AM
bob arrington's Avatar
bob arrington
If I read this forum right , you will need a 390 crank to go with your pistons and rods, that would give you a 390, the heads are probably the same , check the numbers , and a cheap way for more power is a camshaft out of a 60'S 390 from a car . bob
Old Nov 9, 2005 | 02:15 PM
fordraceboy's Avatar
fordraceboy
thats pretty much the gist of it... 390 crank and rods with 360 pistons, then the 390 car camshaft and she'll run pretty decent for low $$$..
Old Nov 10, 2005 | 11:39 AM
460man's Avatar
460man
390
i also have plently of 428 cranks to get my hands on to make a 410
Old Nov 10, 2005 | 12:42 PM
Mike G's Avatar
Mike G
428 crank with 390 rods and pistons. Get that puppy internally balanced.
--Mike
Old Nov 10, 2005 | 01:29 PM
460man's Avatar
460man
it would already be internally balanced wouldnt it
Old Nov 10, 2005 | 01:36 PM
fordraceboy
no.. the 428 cranks are externally balanced, therefore you need the crank nose counterweight and 428 specific flywheel. or just get it all zero balanced.
Old Nov 10, 2005 | 02:15 PM
alleykatt's Avatar
alleykatt
This is a question I have had for sometime. I am sure someone here can answer it.I am assuming that all f.e. engines have the same basic block and heads, the differances being bore,stroke,pistons, cam, crank,etc. If this is the case, what was the point of creating the 428 when we already had the 427.
Old Nov 10, 2005 | 03:18 PM
fordraceboy
the 427 was created to race pure and simple.. the tolerances were much closer and it was not a production practical engine.. the 428 was easier and more cost effective to build and was quite a bit more streetable.. thats te short answer... lol
Old Nov 10, 2005 | 03:28 PM
alleykatt's Avatar
alleykatt
Thanks fordraceboy,the short answer was perfect.
Old Nov 10, 2005 | 07:33 PM
fordraceboy
anytime.. i like short versions myself- less brain strain.. LOL
Old Nov 10, 2005 | 08:31 PM
rusty70f100's Avatar
rusty70f100
You guys are missing something here. There are different types of 390 pistons. There are the car pistons, some with a dish and some with a flat top. Then there are the truck pistons, dished with a low compression height.
Car pistons in a 410 will put the pistons at least .070" above deck at TDC. Not good. The correct 390 truck pistons will be between .010" and .030" below deck at TDC, depending on which manufacturer you choose.
Old Nov 11, 2005 | 11:48 AM
460man's Avatar
460man
ok
so what all do i need to do and look for?
Old Nov 11, 2005 | 12:14 PM
rusty70f100
As far as the short block is concerned, this is what I would do:
1. Get the 428 crank internally balanced. Not really a necessity, but makes things later on so much simpler. (zero balanced flywheel)
2. Recondition the 390 rods and use ARP bolts in 'em.
3. Use 390 truck pistons. This would be the KB-Silvolite #1139, or Summit part number STL-381P.
Then it gets fun with heads, cams, valvetrain, etc. I'll leave that for later.
