Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Ugly duckling?
Old Mar 10, 2008 | 06:34 AM
  #91
96sherm's Avatar
96sherm
3sp OD??? what tranny is that?? most of those years were the c6-3sp, or 4sp man.
Old Mar 10, 2008 | 12:06 PM
  #92
preppypyro's Avatar
preppypyro
Was that called a AOD? My reg cab shortbox has an AOD but I couldnt tell you what the shifter reads off of the top of my head.
Old Mar 10, 2008 | 03:38 PM
  #93
66slick's Avatar
66slick
Yeah AOD, But like I said there is only three speeds.(O-D-1)
The overdrive is pretty good, but in a brisk head-wind shifting to D causes the motor to rev higher than I would like.
I had never seen a tranny like this before I bought this truck.
Old Mar 10, 2008 | 04:26 PM
  #94
Fomoko1's Avatar
Fomoko1
Your`s is a three speed and a lock up torque converter or is it an actual 3 speed overdrive auto?
Old Mar 10, 2008 | 04:31 PM
  #95
preppypyro's Avatar
preppypyro
Ive got one of those just sitting in the back of my one truck, with very low miles on it
Old Mar 10, 2008 | 04:35 PM
  #96
Fomoko1's Avatar
Fomoko1
I have an extra aod too and I`m tempted to use it in the 53 M100/302.
Old Mar 10, 2008 | 04:41 PM
  #97
preppypyro's Avatar
preppypyro
I would too if you have one laying around. Just beef it up a little bit and it would be perfect.
Old Mar 10, 2008 | 06:53 PM
  #98
51dueller's Avatar
51dueller
You have an AOD which is a 4spd transmission. 4th is overdrive and 100% lockup. 3rd gear has 75% lockup.
Shift patterns:
(P-R-N-O-D-1) Truck/Crown Victoria/Town Car etc
(P-R-N-O-D-2) Mustang
Gear Ratios:
2.47 / 1.54 / 1.00 / 0.67
Old Mar 10, 2008 | 07:03 PM
  #99
66slick's Avatar
66slick
I'm confused! Or thick headed? Still see only three gears O-D-1.
Old Mar 10, 2008 | 07:08 PM
  #100
51dueller's Avatar
51dueller
Not every transmission allows you to select every gear. You just can't force the transmission into 2nd gear.
O - Allows all 4 gears to be used
D - Allows up to 3rd gear
1 - 1st gear only
If you have a tach, you can tell when it shifts gears by watching the RPM's change.
Part of the reason you can't select every gear is Ford used the same steering column for all it's automatics. The C-4/6 transmissions only have 6 detents and to make the AOD compatible it can't select 1st or 2nd gear (depends on model). The other nice thing is you can put an AOD in an older car and retain the stock column yet have overdrive.
Old Mar 10, 2008 | 07:14 PM
  #101
66slick's Avatar
66slick
OK! I see the light. To bad I don't have a tach. Would my third gear be lower than a regular three speed auto's?
Old Mar 10, 2008 | 07:21 PM
  #102
51dueller's Avatar
51dueller
All Ford's older automatics have the same 1.00:1 ratio in 3rd gear. Just with the AOD it has a partial lockup in 3rd gear so it will run at a slightly lower rpm. The C-4/6 transmissions will run approx 300 rpm higher than a manual transmission in direct gear and the AOD will run about in the middle of the two.
With the newer automatics the computer can command a lockup in any transmission gear by controlling the clutch. This is why the newer vehicles can get the same highway mileage as a manual transmission version.
The AOD doesn't have a typical lockup converter as one of the main input shafts is splined directly to the front of the torque converter where as the modern transmissions use a clutch lockup.
Old Mar 10, 2008 | 08:58 PM
  #103
preppypyro's Avatar
preppypyro
I didnt know that the manual actually was at lower rpms then the AOD.
Old Mar 10, 2008 | 09:23 PM
  #104
96sherm's Avatar
96sherm
all i know is the c6 is awesome until you do 110 for extended periods of time... then its a headache!!
Old Mar 10, 2008 | 09:34 PM
  #105
preppypyro's Avatar
preppypyro
Its tough for sure. I know there is ford trannies with OD that are supposed to be just as tough. Some guys say the Aod, some guys say the E4od (might have the name wrong).
