Glow plug ohms
Old Mar 1, 2008 | 03:44 PM
westtntrucker's Avatar
westtntrucker
Glow plug ohms
I checked the Ohms on my GP's and got a reading of .001 on all except for 1 which had .018.
Have read that a good reading will be .8 or so.
Am not real handy with a multi-meter and its operation.
Does this sound right?
Old Mar 1, 2008 | 04:13 PM
tjbeggs's Avatar
tjbeggs
Not really, Does you meter have more than one ohm range setting? Sounds like you are in the 1K ohm range. You want to be in the 100 or 10 ohm setting (some meters are 200 or 20 ohm as well)
Old Mar 1, 2008 | 04:52 PM
westtntrucker
Ok, I am still trying to learn how to use a multi-meter. Went back out and rechecked. Starting with the passenger side bank front to rear, 0.7 19.7 0.7 0.6 Driver side front to rear, 0.7 0.7 no reading 0.7
So from this i take away i have 2 bad (maybe one thats not plugged in under the VC) GP's
Looks like next weekend is glow plug replacement day.
Old Mar 1, 2008 | 05:01 PM
tjbeggs's Avatar
tjbeggs
Yeah that sounds better. Which setting did you use on the meter?
Old Mar 1, 2008 | 05:06 PM
westtntrucker
200
Our trucks use the ZD-11 right?
Old Mar 1, 2008 | 05:07 PM
tjbeggs's Avatar
tjbeggs
Yep ZD-11 or the old number is ZD-10. You are correct in that you have 2 bad plugs or wiring issues. Since its 1 on each bank it probably the GP's themselves.
Old Mar 1, 2008 | 05:08 PM
westtntrucker
ps... I see your not using the Cadillac water anymore, Get to expensive?
Old Mar 1, 2008 | 05:09 PM
tjbeggs's Avatar
tjbeggs
that was Kawa. I think he is still shelling out the big bucks for it. I use BMW washer fluid!! LOL
Old Mar 1, 2008 | 05:12 PM
westtntrucker
Oh, ok. Now to look for the zd11's
Old Mar 1, 2008 | 05:52 PM
c00nhunterjoe's Avatar
c00nhunterjoe
ebay has several sets right now for 42 bucks a set
Old Mar 1, 2008 | 06:02 PM
westtntrucker
The only place around here that has the zd11's is Orielly's auto parts, will order them from there. 9bucks a piece. can not do it till next weekend anyway. Have to be up in Charleston WV sunday night.
cjgray1974
Apr 10, 2014 06:28 PM
theduke308
2004 - 2008 F150
Jun 21, 2012 02:52 PM
rehpig
Nov 30, 2011 05:04 PM
Jager
Nov 24, 2010 03:41 PM
