Breaking and entering
Old Mar 1, 2008 | 11:26 AM
ToyoDiesel's Avatar
ToyoDiesel
Anybody know the easiest way to break into an extended cab. I locked my keys in yesterday, and my extra is nowhere to be found.
Old Mar 1, 2008 | 11:33 AM
JethroF250's Avatar
JethroF250
Do you have a sliding rear window?
Old Mar 1, 2008 | 11:40 AM
884x4broncoII's Avatar
884x4broncoII
if you can get a kife inbetween the wind wing and pry up on the leaver and get it open it may help if you can get somthing bent and threw there to press in the button, or drill out the riviets on the wind wing and re rivet it back on. or call AAA or a lock smith. the last two are probably your best option
Old Mar 1, 2008 | 12:03 PM
ToyoDiesel's Avatar
ToyoDiesel
I do have a slider.
I may have to call someone, but that is a last resort.
Old Mar 1, 2008 | 12:05 PM
c00nhunterjoe's Avatar
c00nhunterjoe
use the remot....pmsl.
but anyway, i locked my keys in the truck once, i used a coat hanger to go through the top right corner of the drivers door and pushed the unlock button, took longer to find a coat hanger and bend it then it did to open the door. use rags so you dont scratch the paint on the door and roof and use something as a wedge to open the gap, worse case a long flat tip screwdriver will work
Old Mar 1, 2008 | 12:12 PM
MADVAN's Avatar
MADVAN
Come on guy's this is public!
Ans in a PM
Bill
Old Mar 1, 2008 | 12:13 PM
884x4broncoII
coon dident think of that, last time i locked my keys in vehical was probably 4 years ago and it was an 86 f150 no power nothing
Old Mar 1, 2008 | 12:32 PM
c00nhunterjoe
that would be a totaly different approach. not sure how to do the non power locks without a lock-out kit.
Old Mar 1, 2008 | 01:10 PM
superduty4x4's Avatar
superduty4x4
This summer, about 2-3 weeks after I started my new job, I locked the keys in my work rig (a dang Chevy to boot!). I searched high and low all over that thing, there was no spare to be found anywhere. I spent about 1-1.5 hours crawling all over trying to figure something out, I even managed to shove a long screwdriver through the grill and pop the hood hoping to find a hole I could get inside the cab through.
I was walking away from the truck to grab a rock to throw through one of the windows when for some reason I turned around and noticed the antenna, which stuck up about 1 foot higher than the cab. I unscrewed it with my trusty Leatherman and grabbed the before mentioned screwdriver. I used the screwdriver to pry to top of the door out, then poked the antenna in and hit the unlock button.
Long story short- c00n's idea is a good one, but if you don't have a coat hanger use your antenna.
Old Mar 1, 2008 | 01:30 PM
westtntrucker's Avatar
westtntrucker
Ans in a PM
Bill
A criminal already knows this stuff. The only people we are gonna "Teach" is a 6 year old.
Old Mar 1, 2008 | 06:18 PM
ToyoDiesel's Avatar
ToyoDiesel
Thanks everyone. The door prying trick (coon's suggestion) worked, and it is amazing how much of a gap you can create without hurting the door. Now is when I get sixteen keys made and hide them everywhere.
Old Mar 1, 2008 | 06:30 PM
c00nhunterjoe
only problem with that is by the next time you lock the keys in the car you will have forgotton where those 16 keys are.....
Old Mar 1, 2008 | 06:38 PM
WALJON's Avatar
WALJON
I always have two butter knives in my box rollin around lol what I do is bend both knives stick one under the rubber on the no draft hook the button and pull next I stick the other knife under the rubber and flick the latch over works good on all older model ford trucks with the no draft window lol
stockscooby
Apr 14, 2016 08:20 PM
Mario Lelo
2009 - 2014 F150
Oct 13, 2014 10:13 AM
ragphoto
Feb 17, 2011 03:47 AM
wmiller
Apr 23, 2009 10:54 AM
clunker86
Electrical Systems/Wiring
Apr 7, 2007 12:47 PM
