ohmed glowplugs
Old Apr 9, 2014 | 08:38 PM
cjgray1974's Avatar
cjgray1974
ohmed glowplugs
I ohmed out the glow plugs on my buddies truck and all the plugs on the passenger side showed 0 ohms but there was continuity. I've read you want them .5 to 2 ohms so does this mean they are bad. Thanks
Old Apr 9, 2014 | 08:54 PM
Pikachu's Avatar
Pikachu
Is it an auto-ranging meter? I borrowed one from my brother that refused to read tenths of a number lower than 1. It would just read zero instead.
Old Apr 10, 2014 | 11:47 AM
montanasteve's Avatar
montanasteve
Yep, check what Pikachu said. If the meter isn't auto-ranging, select a lower range, like 10 ohms (max). Then you should be able to read down to tenths of an ohm. They should all be in the .8-1.0 ohm range.
Old Apr 10, 2014 | 01:16 PM
retiredsparky's Avatar
retiredsparky
Glow plugs can certainly fail in a shorted condition (which would result in 0 ohms reading with a selected range on the meter). But if that happens, the overcurrent device would operate and/or the glow plug relay would fail in a blown out open position. So you are correct to figure out whether the glow plugs are shorted as a first step, rather than replacing the relay or overcurrent device. Bad glow plugs can be difficult to remove if they have overheated.
Old Apr 10, 2014 | 04:02 PM
cjgray1974's Avatar
cjgray1974
Thanks. I'll its a fluke t5-600 just looked and it doesn't go below 1. think I have another tester somewhere. I'll have to find it and see if it will show decimal points.
Old Apr 10, 2014 | 04:08 PM
Clay H's Avatar
Clay H
They are good or it would read something like 40
Old Apr 10, 2014 | 06:28 PM
cjgray1974's Avatar
cjgray1974
Thanks, He did have 1 that was open but I think his no start was batteries. He took it in to napa and had them checked and one was only showing 440 amps. so he bought 2 and it started alot better.
Told him we need to pull vc off this summer and see whats up with the one showing open.
my1993f250
Oct 29, 2007 12:33 PM
HUNTER10
Aug 15, 2006 09:37 AM
rdstroker00
Jan 25, 2006 11:33 PM
fast freddie
Nov 9, 2004 07:38 PM
