Sponsored by: Auxito
Plug Wires?
Old Feb 29, 2008 | 04:11 PM
KingRanchMan02's Avatar
KingRanchMan02
Originally Posted by jonrob
ok so there are no wires on the cop that need changing? I guess I just need plugs then.
There is a coil sitting directly on top of each spark plug. 8 spark plugs and 8 COPs. Good luck!
Old Feb 29, 2008 | 04:59 PM
F4L956's Avatar
F4L956
for the ones that do have spark plug wires 4.6/4.2
I used Magnecor 8mm and they seem to work just fine on mine, felt a real difference with a good set of sparks. quick acceleration!
Old Feb 29, 2008 | 11:37 PM
Club Wagon's Avatar
Club Wagon
No. That's not what we're saying. There are no high voltage resistor spark plug wires to go bad. It is possible the ordinary low voltage wires & connections that go to the COP to develop problems. These shouldn't be ruled out, but they're part of the motor wire harness-not really consumable/replaceable like conventional spark plug wires.
FORD scheduled maintenance probably gives 100,000 miles between spark plug changes.
I'd suggest searching FTE for 'blown spark plug' & 'changing spark plugs' before attempting to change the plugs. There are horror stories about stripped threads in aluminum heads & valuable suggestions.
There have been a number of comments about the boots under the COP going bad resulting in misfiring & the tip that they're available separately.
Mikeman
Feb 14, 2015 09:51 AM
johngeorge
Jan 28, 2013 08:59 PM
garrett_8
Nov 21, 2012 02:53 PM
octaneforce
Apr 17, 2011 07:36 PM
88n94
General Automotive Discussion
21
May 17, 2008 04:57 PM
