Spark plug wires help
Old Jan 27, 2013 | 08:27 PM
johngeorge's Avatar
johngeorge
I have always just purchased Motorcraft plug wires but a friend recently told me that Motorcraft's wires are no better than the generic wires from the parts stores. He said I should go with Accel or Mallory. I'm just wondering if someone can help fill me in on the differences and tell me why certain brands are better. Thanks
Old Jan 27, 2013 | 08:59 PM
Evan_P's Avatar
Evan_P
I honestly don't really know what the difference is. I am running Ford Racing 9MM wire's because I was recommended them when doing my ignition tune up with hotter ignition parts. The way I see it, if the Motorcraft ones haven't let you down, no need to change.
Old Jan 27, 2013 | 09:38 PM
blkF250HD's Avatar
blkF250HD
I've noticed that better quality wires are generally closer to an exact fit vs being a mile too long. OEM, NGK, Denso, Bosch, all make decent wire sets. The cheap Autolite, Duralast, BWD, etc will get the job done just not fit very well.
Old Jan 27, 2013 | 11:44 PM
Blurry94's Avatar
Blurry94
On a mostly stock vehicle, The Ford Racing wires work well and yield a lower resistance than many OEM type wires. Most stock plug wires will read about 2K ohms per foot, or higher, and the Ford Racing wires read about 1K ohm per foot.
If you're looking for the lowest resistance per foot, then the MSD Superconductor or Taylor Thundervolt wires are about your best bet. Both companies claim 50 ohms per foot but the cost is going to be higher than the Ford Racing wire sets.
I purchased a roll of the MSD wire and made my own plug wires so that the lengths would be just right. I remember measuring the resistance on mine and all of the wires measured slightly less than 50 ohms per foot.
Old Jan 28, 2013 | 08:59 PM
johngeorge's Avatar
johngeorge
Thanks for the input guys.
Meridian_Mike
27
Jan 21, 2019 07:03 AM
Mikeman
Feb 14, 2015 09:51 AM
Sw1tchfoot
23
Dec 15, 2010 09:36 PM
txzaphod
Aerostar
Sep 15, 2004 12:28 PM
christop43
1978 - 1996 Big Bronco
Nov 23, 2002 09:06 AM
