Offroad & 4x4
T-Case?
Old Feb 21, 2008 | 04:42 PM
MER's Avatar
MER
T-Case?
Which Transfer Case Do you all like best the BW1345 or the NP208?
Old Feb 21, 2008 | 05:15 PM
chrono4's Avatar
chrono4
they're both chain driven aluminum cased t cases. The b/w has known to have issues with the oil pump spinning out and burning up the case, but this can happen with any case.
MBBFord's Avatar
MBBFord
Neither......
both aluminum cases with about the same low range and strength
Don't hear more complaints from one particular one over the other.
What you trying to use it far.
Old Feb 21, 2008 | 05:21 PM
MER's Avatar
MER
THANKS! Just Normal Driving and some 4Wheeling!
Old Feb 21, 2008 | 05:27 PM
MBBFord's Avatar
MBBFord
For nothing serious, either will work, but I'd look for one with a manual shifter.....
You looking to buy a truck, or replace a t case?
Old Feb 21, 2008 | 06:17 PM
MER's Avatar
MER
Just to replace, I have got the BW 1345 right now but its down and i was wondering to repair or replace ,how does the NP205 do,and will it bolt to my NP435?
Old Feb 21, 2008 | 06:26 PM
MBBFord's Avatar
MBBFord
Well the NP205 is a great t-case, and very, very strong.
It will bolt to the adapter, same bolt pattern, but from what I hear it isn't a dirrect swap, and would be more trouble than if you put another BW in.
Old Feb 21, 2008 | 06:51 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
I think the drive shafts will be different as the 205 is a thicker case IIRC
Old Feb 21, 2008 | 07:13 PM
captain p4's Avatar
captain p4
speaking of transfer cases.. you get the driveshaft issue fixed yet Matt?
Old Feb 21, 2008 | 07:20 PM
MBBFord's Avatar
MBBFord
hahaha.... nooooope.
I'm hoping a custom yoke will work. Instead of buying a $150 yoke, I'm waiting for Ivan to take his off(he's about to upgrade)....
How's the tranny and cab swap going?
Old Feb 21, 2008 | 07:23 PM
captain p4's Avatar
captain p4
Pulled the front clip off the parts truck and disconnected everything, waiting for the bobcat specialist to pluck it off of there for me. Then I have to do the same to my bronco and Ill swap the trannies without the bodies on to make it a little easier. I pretty much only have sundays to work on them, so its going, but just not very fast lol
Old Feb 21, 2008 | 07:58 PM
MBBFord's Avatar
MBBFord
More progress than I'm getting....
There are thinks I'd like to do, but until I have a front driveshaft, I won't waste my time on them.
Old Feb 21, 2008 | 08:03 PM
MER's Avatar
MER
Thanks! Do you all hear any thing bad on the T-Case chains?
Old Feb 21, 2008 | 08:11 PM
MBBFord's Avatar
MBBFord
They can stretch out and may need to be replaced, but they usually stretch after 150,000+ miles if you aren't running anything extream.
DutchmanAZ
May 31, 2002 02:42 PM
MartyB
May 17, 2002 07:27 PM
emboyd
1978 - 1996 Big Bronco
Apr 3, 2002 01:40 PM
mlb
Jan 1, 2001 07:38 PM
vapor
Feb 9, 2000 09:14 PM
