1978 - 1996 Big Bronco
flexplate help
Old Feb 20, 2008 | 02:44 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Bimmerboy1989
I'm sorry it took a few days for me to get back. I found that a 79 Ford pickup with a 351w and a C6 transmission takes a fra-202 flexplate. This flex plate should fit what you have.
Impossible, only passenger cars (including Ranchero's) & 1975/79 Econolines had 351W engines thru 1979.
No 351W engines in F Series trucks till 1981.
351W flexplate used in FoMoCo passenger cars/Econolines with a C6 transmission:
1974/76 & 1979 cars / 1975/79 Econoline:
DIZZ-6375-A / Marked: D1ZP-AB / 164 tooth ring gear
This same flexplate was also used with some 302 C6 applications 1978/80.
The above information comes straight from the official 1973/79 Ford Passenger Car & 1973/79 Ford Light Truck Parts Catalogs.
Old Feb 20, 2008 | 02:47 PM
dragogt's Avatar
dragogt
Impossible, only passenger cars & 1975/79 Econolines had 351W engines thru 1979.
then which one would I need?
Old Feb 20, 2008 | 02:57 PM
NumberDummy
Info and Ford part number added above.
Old Feb 20, 2008 | 03:01 PM
dragogt's Avatar
dragogt
Cool, thanks NumberDummy.
Old Feb 20, 2008 | 03:10 PM
NumberDummy
The flexplate is obsolete from Ford (I just checked) and Green Sales doesn't have one, so you'll have to go to the aftermarket sector to locate one.
The same D1ZZ-6375-A flexplate also used on:
1980/81 Econoline 351W C6 except CA
1982/89 351W (all variations) C6 Econoline/Bronco/F100/350
302 C6: 1978 F100/150 with T/E (smog pump) / 1979/80 Econoline/F100/150
and...
1971 Torino & Mustang 351C 4V C6 except CJ (the original application)
1972 Torino & Mustang 351W & 351C 2V C6
Old Feb 20, 2008 | 04:16 PM
Kemicalburns's Avatar
Kemicalburns
can you locate the flexplate for an 80's crownvictoria with the 5.8/AOD combo
Old Feb 20, 2008 | 04:37 PM
dragogt's Avatar
dragogt
Yep, parts house. not trying to be smart azz, But wont that be the wrong weight?
Old Feb 20, 2008 | 04:44 PM
dragogt's Avatar
dragogt
and...
again I say Thanks NumberDummy, for the research
Old Feb 20, 2008 | 05:33 PM
Bimmerboy1989's Avatar
Bimmerboy1989
Ok, Maybe I lied a little on th application. That flywheel is for a 82 bronco with 351 and c6. The fra202. It is also listed for a 80 econoline. I don't remember which OEM number is listed for it, but when you go ot O'Reilly have them pull you the pioneer flywheel book and in the illustration guide look at the flywheel fra202 and it will list it's OEM ford number. Since you have a OEM ford number now then you can just match it to one of the ones in the book.
Old Feb 20, 2008 | 05:35 PM
Bimmerboy1989
Oh, also in the computer it lists for a 79 f-series(not saying it is right) two 351s. It lists the 351m and the 351w.
Old Feb 20, 2008 | 10:19 PM
NumberDummy
Which would tend to believe..the '73/79 & '80/89 Ford truck parts catalogs, or some aftermarket catalog?
351M 1977/82 F100/350 & Bronco
351W 1981/ F100/350 & Bronco / 1975/ Econoline
As stated above in POST #20, the 1982 Bronco 351W C6 uses the SAME flexplate (D1ZZ-6375-A) as 1982/89 F100/350 & Econoline, and all the other applications I listed in POST 16.
Originally Posted by =Kemicalburns
can you locate a flexplate for an 80's crownvictoria with 5.8 (351W) AOD combo?
Sure...
351W/AOD used in: Crown Vic/Merc Grand Marquis/Lincoln Town Car
EOAZ-6375-A .... Flexplate
It's STILL available from Ford.
From FTE sponsor y2kfordparts (Millennium Ford-Seattle).
Ford suggested retail price: $81.34 / FTE member price: $65.40
You can call them...(206-431-7331) and ask for Kenny, or use their online link.
Type the part number into their link like this: eoaz6375a
Old Feb 21, 2008 | 08:44 AM
Bimmerboy1989
Yeah, It's a aftermarket catalog. It's our electronic catalog at work. It's right at least 50% of the time. I do remember the tooth count on the flywheel, it was 164.
andrew's64
Aug 6, 2016 05:50 PM
bankog1
Oct 23, 2015 11:50 AM
GreatNorthWoods
16
Apr 20, 2011 04:29 PM
mrfox0246
May 24, 2010 08:31 AM
Handegard
May 10, 2007 02:39 PM
