Flexplate questions
Old Aug 4, 2016 | 07:10 AM
andrew's64's Avatar
andrew's64
Flexplate questions
I'm in the process of trying to figure out what flexplate I can use. Ok well I have a 1986 351w with a c6 bolted to it. I'm trying to figure out what flexplate I need or can use to mate the 351w to a FMX transmission. Also can I use the engine block plate or do I need to find one also to use with FMX?
Old Aug 4, 2016 | 08:36 PM
kenny nunez's Avatar
kenny nunez
Flex plate
I have never tried what you want to do. However first make sure the holes in the plate line up with the FMX converter. If so, check that the converter nose is compatible with the crankshaft center bore. Re use the block plate, then try to mate the engine and see if the converter has about 3/8"-1/2" gap between the flywheel. If all this lines up it should work. Good luck
Old Aug 5, 2016 | 09:44 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D1ZZ-6375-A .. 351W Flexplate.
1980 all 351W 2V / 1982/86 F150/350, Bronco & Econoline 351W 2V / 1984/91 all 351W 4V & EFI / Misc 1971/79.
Old Aug 5, 2016 | 10:12 AM
andrew's64's Avatar
andrew's64
So that flexplate will work with my 1986 351w 4v motorhome engine to bolt up and use a transmission?
Old Aug 5, 2016 | 10:50 AM
351Cleveland C4's Avatar
351Cleveland C4
Yes. Flexplates are for the engine, not the transmission.
Old Aug 5, 2016 | 03:31 PM
andrew's64's Avatar
andrew's64
I understand that but there are also different offset flexplates correct? Also when you look up that flexplate part number it says it's for a c6 transmission. So the existing flexplate that's on the engine bolted up to the c6 will work with the FMX. Sorry if I'm not understanding all this.
Old Aug 5, 2016 | 04:38 PM
351Cleveland C4
It all sounds much more complicated than it is.
Yes, there are flexplates that have different offsets, but for the most part, they are all standard in the same group of engines.
Reason it says it's for a c6 is because that year of engine never had an FMX behind it. Only a C6.
Old Aug 5, 2016 | 07:46 PM
Ford_Six's Avatar
Ford_Six
Did the balance on the 351w change or was that just the 302? I had a 351w and FMX in my 70 Galaxie 500.
Old Aug 5, 2016 | 07:49 PM
NumberDummy
Pic: Scroll down to 6375: Here are the 1980/89 D1ZZ-6375-A applications.
The only specific C6 is 1981 E100/350 which I didn't list, as it was irrelevant for your application.
So, it was used with 351W C6, AOD and beginning in 1989, with E4OD
The only trucks that used an FMX were 1973/77 F350's with 300 I-6. No other F100/350, Bronco or Econoline used the FMX
It was mainly used in 1969/89 FoMoCo passenger cars.
Old Aug 5, 2016 | 07:58 PM
351Cleveland C4
Just 302. 351 remained at 28oz throughout its life.
Old Aug 5, 2016 | 08:07 PM
ultraranger's Avatar
ultraranger
....and only the H.O. (High Output) 5.0L engines had the same firing order as the 351W/5.8L engines (1-3-7-2-6-5-4-8) vs. the non-H.O. 5.0L engines (as well as 289s/older 302s) firing order of 1-5-4-2-6-3-7-8.
Old Aug 6, 2016 | 04:58 PM
andrew's64's Avatar
andrew's64
I'm sorry but I'm so confused. I just don't wanna pull apart the vehicle to swap the engine to find out the flexplate I have which is the part number you suggested will not work with the FMX transmission I'm trying to bolt it up to. Sorry if I'm getting annoying about this I just want to make sure it will work before I do it.
Old Aug 6, 2016 | 05:20 PM
351Cleveland C4
THE ANSWER IS YES!
we've given you the all information you need and then some, and told you directly and indirectly roughly 4 times now.
YES IT WILL WORK.
I can't put it any more plainly than that...
Old Aug 6, 2016 | 05:40 PM
andrew's64's Avatar
andrew's64
THE ANSWER IS YES!
YES IT WILL WORK.
sorry I just wanted to be totally sure it'll work. Thanks for all of your guys info and time. Its really appreciated
Old Aug 6, 2016 | 05:50 PM
351Cleveland C4
Don't over complicate things for yourself. Ford was pretty good about keeping things normal and standard. Some variations of course, but every part wasn't a one-off special production...
unclejunk
17
Feb 15, 2010 11:09 AM
dotcentral
1978 - 1996 Big Bronco
May 22, 2008 09:35 AM
Graffe
Apr 10, 2002 11:29 AM
lghtnin351
Oct 16, 2001 10:04 AM
