i was wondering about turning my motor over to fuel injection I have heard that you can gain about 100 horsepower for about $800 for a new one. I dont want to spend that but will a factory fuel injected 429/460 intake fit. I thought they were pretty close it would be better if i could find a 400 FI but I havent ever seen one.
probe industries will make a efi intake for you. the cost is about $758.
i cant remember if its a 351C torker 2 intake or not. if it is you will have to use the weiand intake plates.
>Is your motor nitrous assisted? 799 hp would be 1.8 HP Per
>Cubic Inch which is high for a naturally aspirated
>engine.Not saying i DON'T BELEIVE IT. Just curious.
>Thanks...
NO it's not nitrous assisted... But you can make lots of power from any engine if your able to take advantage of all it breathing capabilities.Put a 1000 Cfm Carb. on it and use all 1000 Cfm to fill this motor and you'll make power.
It's hard to say how much potential is left in ShaZam's motor. I would think that Yates, Blue Thunder, SVO, Ultra Flo Machining, CHI, and Arao would flow more air than the cast iron heads with port plates.
I'm wondering what the power limit is for the block.
As far as long stroke motors are concerned, it sound archaic like the old flatheads, but in reality, it's a modern practice with Ford Modulars.
The 5.4 and 6.8 V10 use a 3.55" bore with a 4.17" stroke. They make excellent low speed torque. The R model Cobra uses a 5.4 with 4 valve heads. This is not a low RPM motor! Since the block is 10.08" tall, they can use long rods that reduce the rod to stroke ratio. The pistons are also very short, so their light weight puts far less strain on the crank and rods.
Correct me if I'm wrong, but I think the Chevys are a lot more limited by a long stroke because of the 9.8" deck height.
400 & 460 are 10.3".
The 4" stroke and 6.58" rods give a 1.645 R/S ratio.
A 4.17" stroke with 6.795" rods is a 1.630 R/S ratio.
That's only a 1% difference.
I wanted a 4.250" stroke with a 6.8" rod. Custom piston. I could sacrifice some rod ratio and go 6.535" rod with a cheaper common 1.600" piston for a 440 CI stroker. People say it'll be crap.
I had dropped down from my original idea of a 4.500 stroke 4.040 bore for 461 CI. I elected to build an actual 460 instead. However, 4.5" crank would have been custom ground. Also, I was told the bore speed would increase with the long stroke and cause a lot of heat / wear & tear. There is a company coming out with one for the Windsor. I may go back to this idea and use a 351W harmonic balancer and add weight to the crank if that'll work.
I don't know where you can find a 4.250" stroke crank unless it's custom ground. If you do get one, there's no guarantee that a 6.535" rod is long enough for the piston to clear the 4.25" crank counterweight.
Proline was supposed to come out with a 4, 4.25 & 4.5" cranks for the 351W. I haven't found any info about pricing or when they'll be available. They would have to be ground for Chevy con rods.
Well this forum is the 335 series engines (I hate Windsors) so post it in the windsor lineup. I dont want to pay $758 for custom FI. So I was wondering if ford ever made this engine in either M or C with FI, again I havent ever seen one but if they exist I don't think that $350 is out of line for a used FI intake. So does anybody know if Ford made this intake in FI and if so will all three fit interchangeably? Thanks
You will never find an M block, or a C block for that matter, with factory EFI. The 351m/400 was discontinued in 82, and the 351c disapeared in 74. One thing you can do, however, is get a 4BBL intake, have an adaptor made, and run CFI/TBI on it. That is the only way you will be able to get EFI on this motor for cheap, but still, you are only talking about 500CFM of airflow.
Don't expect higher peak hp from fuel injection. You may get more area under the curve, beter fuel economy and throttle response but not peak power unless it's a race set up.
Also in the last copy of Hot Rod (I think) the had the result of an engine builders contest. A 307 long stroke chevy finished surprisingly high competing against 350ci limit.
You have to take generalities with a grain of salt. Also everyones entitled to their own stupid opinion. :P
Ok no FI for me because I have better things to spend $800 on. Like a Demon. The one I have on a 390 in a '68 kicked das Scheissen out of the edelbrock and holley that were one there before. Ive already got an aluminum 4 bbl intake so all that I need is the carb and I should be set. I don't need to complain about a 400 not making enough power, this one already pulls the pants off of a 460. thanks
That's what I'm interesting in doing.Building a 400 that will put the hurt on a 460 at a small block ford weight of 480 lbs or less. I'm trying close in on the cubic inches advantage it has over the 400's 402 cubic inches. 58 CI of displacement difference. The aftermarket support is so great for the 460 it really makes it hard.
yeah I hear you "D" I think that you can make a lot more power and save a lot of weight if you go with the 400 over the 460 But i hope this doesnt cause a run on the yards. oh well they yards are littered with tons of 351M/400M engines and they both make very respectable power.
