Trouble with 1986 302
Old Jan 23, 2008 | 01:25 PM
forg's Avatar
forg
Hi i've been reading this forum for two months and it has helped me allot with getting my 1986 e150 Club wagon started so thanks for that.
With it running i was able to do the koer test and thoght i could run that by you ford experts .
KOEO
11-11-1-18-18. 11=System pass. 18=The list on fordfuelinjection.com dose not give 18 as a possibility in this test except in continues memory.
KOER
12-22-16-12-22-16 12=cannot control Rpm during ER self test high rpm check.
22=MAP/BP sensor out of self test range.
16=RPM too low to perform Hego test.
The list that i've done is short sparkplugs, distributor cap,rotor.spark plug wire's,
stator,EVP,oxygen sensor ,low pessure fuel pump (the previous owner changed the hi pressure one and filter with no luck) so my qestion is are these codes connected (something causing the other)ornot and how do i go about fixing it.
My humble apology for misspellings and stupid sentences English is not my first language and thanks for your help.
Old Jan 23, 2008 | 06:54 PM
mhg's Avatar
mhg
possible that the map sensor is out and need to check
your idle air bypass motor
test both of these and check all your grounds
thetowerig
Mar 7, 2014 11:31 AM
SideWinder4.9l
Jul 30, 2011 08:29 PM
Homeslice
13
Jul 3, 2011 10:27 AM
Truck Builder 1
Aerostar
31
Mar 27, 2006 09:50 AM
minexist
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Nov 18, 2003 06:20 PM
