heater does not work
Old Jan 21, 2008 | 03:15 PM
72soa's Avatar
72soa
I have a 1997 E super duty van/motorhome. (v-10) The heat from the dash does not work. The blower works fine and the a/c works fine. All vents work fine (defrost, etc) I just cannot get any heat. I thought that the dial control that controls air temp was bad and took the unit apart with the intent of buying a new control unit. However, in a search on this forum there appears to be a door that does not want to work in the heat system. Should I put the controler back together and work on the door system? Any insight into this issue would be appreciated.
Old Jan 23, 2008 | 09:54 PM
ubereal2's Avatar
ubereal2
Does you're temp gauge show that you have good warm engine temp? Are you're radiator hoses, and hoses going to and from the heater core warm too? Is the radiator low?
Old Jan 24, 2008 | 07:51 AM
94van's Avatar
94van
Not sure about your particular van, but most have a water control valve in one of the heater hoses under the hood near the firewall. It has a vacuum line going to it.
They sometimes lock up, or maybe the vacuum hose is leaking.
Az2008f350psd
Jan 30, 2012 02:25 AM
jimnkaran
Nov 11, 2011 10:02 AM
big nd fan
May 13, 2011 11:33 AM
denali05
Dec 27, 2009 02:02 PM
chaneyb
Aug 20, 2007 09:53 PM
