i am trying to switch my six cyl to a 302 in my 66 f100 im told the perches will not work will the perches work from a early 70s bronco with a 302 or can i shorten up the six pearches
thanx paul
Paul, There are only 2 perches not 6, afaik. When looking at them the 302 perches angle back towards the firewall where as the I-6-FE perches are more straight out. I think I read that the 400 M uses them also, so there could be more choices.
I believe you will have to look in 68-79 trucks for them, but can not advise on the bronco.
swaping out my 240 6 cyl to a 302 in my 66 f100 got pearches from a 75 f100
the bolt holes line up on top but not on botom do i just need to drill new bottom holes or re mount the entire pearch anybody got tips or now where there is article to point the right direction
thanx paul
When I converted from a 300 to a 302; using the perches that came from a 66 model F100 with a 76 model 302 as a donor truck I use; I had to move the perches back to the last upper holes, I believe and one lower hole line up, it was the front lower one that line up. I then drill the lower rear hole to fit. The only issue after doing this was my oil drain plug was too close to the crossover frame mount; for which leaving my perches in the holes I mention , cause me to have too drill a 1 1/2" hole into the crossmember to allow me to unscrew the drain plug completely to change my oil. also my C-6 seem very tight to install as well; but was able to do so.
