I am about to swap a 351m into my 78 f250 4x4. I have a set of 302 perches, will this work or do I have to go hunting for 351m perches?
Thanks in advance
Greg C
Even if you moved the perches they would be too far apart, The 6 is a narrower block. If you were to move them you would probably have to weld them to the frame and use spacers under the rubber mount next to the block and find longer bolts, I am just guessing but I think you would need about one and a half inches per side. Just a thought I ve never done it.
