engine perches
Old Jan 19, 2008 | 01:20 AM
juchertf100's Avatar
juchertf100
Question engine perches
i am trying to switch my six cyl to a 302 in my 66 f100 im told the perches will not work will the perches work from a early 70s bronco with a 302 or can i shorten up the six pearches
thanx paul
Old Jan 19, 2008 | 05:59 AM
jowilker's Avatar
jowilker
Paul, There are only 2 perches not 6, afaik. When looking at them the 302 perches angle back towards the firewall where as the I-6-FE perches are more straight out. I think I read that the 400 M uses them also, so there could be more choices.
I believe you will have to look in 68-79 trucks for them, but can not advise on the bronco.
John
Old Jan 19, 2008 | 06:51 PM
garbz2's Avatar
garbz2
Bronco perches do not work.
you need small block 302 perches or 351M 400 perches form any 69 to 79 ford truck.
Garbz
The 300 perches work but place the engine too high in the chassis. And create drive line issues along with exhaust clearance issues.
Old Jan 19, 2008 | 11:59 PM
juchertf100
thanx guys i found a set out of a 1975 f100
paul
Old Jan 20, 2008 | 03:41 PM
juchertf100
Question
ive removed te old pearchers set the new ones in and the bolt holes only line up on top any sugestions on how to place them or were to place them
thanx paul
Old Jan 20, 2008 | 11:40 PM
juchertf100
Question 302 paerches
swaping out my 240 6 cyl to a 302 in my 66 f100 got pearches from a 75 f100
the bolt holes line up on top but not on botom do i just need to drill new bottom holes or re mount the entire pearch anybody got tips or now where there is article to point the right direction
thanx paul
Old Jan 21, 2008 | 06:15 AM
jowilker's Avatar
jowilker
Paul that has been covered several times but I don't remember if you drill another hole or move the perches to another set of holes.
Use the search feature and see what pops.
John
Old Jan 21, 2008 | 05:38 PM
Customcab's Avatar
Customcab
When I converted from a 300 to a 302; using the perches that came from a 66 model F100 with a 76 model 302 as a donor truck I use; I had to move the perches back to the last upper holes, I believe and one lower hole line up, it was the front lower one that line up. I then drill the lower rear hole to fit. The only issue after doing this was my oil drain plug was too close to the crossover frame mount; for which leaving my perches in the holes I mention , cause me to have too drill a 1 1/2" hole into the crossmember to allow me to unscrew the drain plug completely to change my oil. also my C-6 seem very tight to install as well; but was able to do so.
Mitch
Green Streak
Engine Swaps
Sep 23, 2019 05:18 PM
squirrel1182
Jul 3, 2012 11:26 AM
302 F-150
Engine Swaps
Jul 7, 2008 06:02 AM
BarryMc
Jan 3, 2008 01:32 PM
rmalottwtes30
Oct 7, 2007 10:39 AM
