Engine perch swap
Old Dec 31, 2007 | 09:56 PM
BarryMc's Avatar
BarryMc
Engine perch swap
I've searched the archives and haven't found a definite answer to this question. When doing my swap from a 240 to a 351w in my 66 2wd, using the perches from a 76 f100 that had a 302, do I have to drill the bottom 2 holes in each perch? today I removed the perches from the 76, tomorrow I'll remove the perches from the 66. thanks
Old Dec 31, 2007 | 10:30 PM
airharley's Avatar
airharley
The best answer off the top of my head would be to make a paper or tape template outlining the location of the bolt holes used by the 302 in relation to the postioning on the crossmember. Take that and compare it to the 66's crossmember perch holes then center punch the missing hole and drill it. I can't tell you which one specifically since I haven't done a perch swap yet.
Old Jan 3, 2008 | 01:32 PM
1964_mezajd's Avatar
1964_mezajd
Mark, So what did you use to get the 460 in your '64? Curious since I have a '64 and I'm looking into changing my engine and tranny as well on mine.
66FORDFAMILY
16
May 16, 2014 06:44 PM
squirrel1182
Jul 3, 2012 11:26 AM
torquemeister
Engine Swaps
Jan 23, 2010 01:20 PM
77FordDW
Engine Swaps
Nov 11, 2008 07:25 PM
mjunk1
Engine Swaps
Oct 26, 2006 06:05 PM
