Auto..uh..trans..uh?
Old Jan 19, 2008 | 09:44 PM
EDMist's Avatar
EDMist
Post Auto..uh..trans..uh?
Hey guys,
What year C4 or C6 transmission will bolt up to my 250 6cylinder motor? I have a manual trans in it now, and definitely want an automatic. Please give me details because im not too familiar with transmissions by ford, and find them a bit more confusing than Chevys. I would also like to post a picture for another question...is that done easily?...if so please help me with that as well, thx
Old Jan 19, 2008 | 10:00 PM
Pickupmanx2's Avatar
Pickupmanx2
You need to give us a year of truck AND engina, years change things you know,,,, like my wifes backside,,,,, used to be a size 3 now it's a 5 going on 7,,,,,,
Old Jan 19, 2008 | 10:04 PM
EDMist's Avatar
EDMist
My truck is a 66 ford flareside 2wd. I changed the manual steering to power. Changed manual brakes to power. And now am ready to change the manual trans to automatic.
Old Jan 20, 2008 | 04:33 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The 250 inline 6 is a passenger car engine first used in 1969.
It was never installed in a F100/350.
1965/74: 240 or 300 I-6. 240 discontinued after 1974.
These two engines used the C-4 transmission, a few 300's used FX Cruiseomatics.
No C6's were used with 300's till 1978.
Old Jan 21, 2008 | 09:33 PM
EDMist's Avatar
EDMist
Well slap my butt and call me Betsy, my motor is a 240. Im a bonehead. Anyways, is a C4 the only tranny that will work with a 66 ford 240 motor then?? If so what years C4 will hook up without too much trouble?
Old Jan 21, 2008 | 09:43 PM
85e150's Avatar
85e150
The C4 with 289-302-351W, and later C6 from behind a 300 will work. Converter and shift points might be an issue.
Now, if you is bare bone$ on this, that's one thing. If you are a little more flush, consider an AOD from the latest models before AODE. There is plenty of propaganda here including what years to watch for. Early ones are dogs, so watch out. TCI only uses 88-93 cores, so them are the ones to look for if you hunt one down.
http://www.transmissioncenter.net/AOD.htm
http://www.becontrols.com/products/aodcat.htm
http://ckperformance.com/ford_aod.html
http://www.tciauto.com/Products/Ford/ford_aod.asp
Good luck.
