Frame Perches
Old Jun 5, 2008 | 09:36 PM
302 F-150's Avatar
302 F-150
Frame Perches
I have a two wheel drive 1980 f100 with a 300 and I will be putting a 351W in it. My question is what frame perches will I need? Will any 1980-1986 windsor perches work?
Thanks
Old Jun 6, 2008 | 08:45 AM
Conanski's Avatar
Conanski
The 302 and 351 utilize the same engine mounts so yes, any 80-86 truck mounts for these motors will work.
Old Jun 6, 2008 | 04:09 PM
302 F-150's Avatar
302 F-150
Do you know if four wheel drive mounts work or do I have to use mounts from a two wheel drive truck?
Old Jun 16, 2008 | 09:19 PM
302 F-150's Avatar
302 F-150
Do they have to be from an f100 or can they be from any 80-86 truck.
Old Jul 7, 2008 | 06:02 AM
hayden01's Avatar
hayden01
When I was looking for frame blocks for my swap I was told that I had to go with a '80-'85 Bronco for my '84 Bronco. But I ended up getting them out of a '90 Bronco.
What I'm trying to say is don't look just in the year range that you hear, look a cupple years out of that year range.
2WD verces 4WD frame blocks...honistlly...I can't help you there. But you are/might have to grind off about 4 or so cold rolled rivits on the driverside tower. At least that is the case on 4WD towers...not sure about 2WD sorry. but I hope it helps you.
Xcr600man
Jan 11, 2016 03:58 PM
Xcr600man
Ford Truck Parts for Sale
Jan 9, 2016 11:28 PM
semi 104
May 16, 2014 08:41 PM
tom from mass
Apr 4, 2014 03:38 PM
squirrel1182
Jul 3, 2012 11:26 AM
