Sponsored by: Auxito
4x4 not engaging
Old Jan 14, 2008 | 11:50 AM
robin1t2002's Avatar
robin1t2002
4x4 not engaging
Hello all,
my dad has a 1997 F250 light duty. It has the switch on the dash for the 4 wheel drive engagment. He says that when he turns the switch to 4hi that he hears a clicking noise in the dash but the 4 wheel drive will not engage. Any ideas?
Thanks
Old Jan 14, 2008 | 02:36 PM
WALLACE84's Avatar
WALLACE84
4x4 module and 4x4 relay. I had the same problem
Old Jan 15, 2008 | 06:38 AM
robin1t2002
Is this the GEM modual or a modual specific to the 4x4? Where is it located?
Thanks,
Old Jan 15, 2008 | 12:55 PM
WALLACE84's Avatar
WALLACE84
On my 99 f150 the module was on back of the fuse box and the relay was by the gauge cluster. Its a pain to tear apart the dash but I bet thats what is going on with yours
Old Jan 15, 2008 | 12:56 PM
WALLACE84's Avatar
WALLACE84
Oh, I forgot to add that it is a 4x4 module (even says it on the box) but it also runs the power windows, wiper motor and something else I cant think of
Old Jan 16, 2008 | 06:33 AM
robin1t2002
Thanks for the info. I will be checking this tonight after work. I will let you know what I find.
Old Jan 17, 2008 | 07:19 AM
nawicks's Avatar
nawicks
There is also a vacuum pump on the front axle. It's located slightly to the passenger side on the back of the front axle and its covered with a plastic sheild. If you don't use your 4 wheel a lot sometimes that becomes stuck and you have to manually work it to break it free. If you look at the pump it has a little piston on it that moves a lever on the differential. If you engage your 4 wheel drive when the trucks on and you don't see the piston push that lever very far you may neet to grab a set of pliers and work that lever back and forth to break it free. Don't wory, you won't break it as long as your not reefing on it really hard. I had to do this to my truck this winter because I would here a click in the dash when I turned by 4x4 but it wouldn't actually engage. Once I worked that switch back and forth a few times the 4 wheel drive works great. This is just one possible solution but you might as well try it.
Old Jan 17, 2008 | 07:29 AM
ncranchero's Avatar
ncranchero
Originally Posted by nawicks
There is also a vacuum pump on the front axle. .
For the sake of not misleading someone, It's a vacuum diaphragm on the front axle not a pump. It operates off of engine vacuum.
Old Feb 10, 2008 | 12:35 PM
WALLACE84's Avatar
WALLACE84
did you ever figure it out?
Old May 19, 2008 | 12:40 PM
robin1t2002
I have had a lot of personal issues the last few months and have not been able to check it out yet. I should be able to this week. Also, my dad told me that when turning the switch to 4hi it clicks and will sometimes engage. When he turns it to 4lo it will not click and it will not engage.
Old Oct 7, 2008 | 07:18 AM
robin1t2002
update on 4x4 not engaging
FINALLY!!
I finally had time to diagnose the 4x4 inop in my dads truck. I got a wiring diagram from a friend. I was able to check the inputs and outputs of the GEM module. I checked the outputs first. They all worked properly except where they received a signal from the GEM. I then checked all the inputs. They all worked properly also. Process of elimination, it's the GEM module at fault.
With the wiring diagram I was able to see where I should have power and ground. I could also connect power or ground where needed to test the relays and shift motor. Since everything else checked ok, it had to be the GEM.
The only inconsistency I found was with the shift switch. The resistance in ohms was slightly higher in all three posistion compared to what the diagram said it should be.
Fortunately I have an old friend that works in parts. Got the module for $205 instead of $280. 4x4 works fine now and my dad can pull his tractor up my steep gravel driveway with no problem.
Thanks everyone for your info.
Ace!
Jan 9, 2008 06:23 PM
Jeff Scha
1997 - 2003 F150
Dec 7, 2007 06:40 PM
roywells
1983 - 2012 Ranger & B-Series
Jun 12, 2007 07:10 PM
BIGTSV
Mar 15, 2005 10:50 AM
BlueOvalFitter
1978 - 1996 Big Bronco
Jul 20, 2004 10:07 AM
