ford ranger 4x4 not working
Old May 30, 2007 | 08:32 PM
roywells's Avatar
roywells
our 2000 Ranger won't engage the 4x4when we try to switch it . The lights on the dash flash but it will not engage the 4 wheel drive
Old May 30, 2007 | 08:50 PM
fflintstone's Avatar
fflintstone
Welcome to FTE roywells, good choice to get pointed in the right direction.
You may have the pulse vaccuum hubs, but they may have discontinued them by 2000, I'm not sure. Someone will be by soon enough to confirm this. Once engaged, it stop flashing and stays on. If you don't have pulse hubs, then the hubs are permanently engaged and engagement for the 4X4 happens in the transfer case. The 4X4 high switch will flash until it senses that it's engaged. There's a shift motor connected to the transfer case that you can check out. Check and clean the wiring leading to it.
Fred
Old May 30, 2007 | 09:17 PM
Rockledge's Avatar
Rockledge
The Pulse Vacuum Hublock system was discontinued in mid-year 2000. Those '98-'00 Rangers/Mazda B-Series that are equipped with PVH have black plastic front hub covers with small screens in the center.
https://www.ford-trucks.com/forums/s...68&postcount=6
See also: https://www.ford-trucks.com/forums/5...ont-go-in.html
Old May 31, 2007 | 06:20 PM
roywells's Avatar
roywells
Thanks for the info. Can anyone elaborate a little more for me?
Old May 31, 2007 | 07:32 PM
fflintstone
The pulse vaccum hubs use vaccum from your engine to engage the hubs into 4WD. Ford discontinued them for a good reason. They're a PITA. The engineer that designed them is probably flippin' burgers for a livin'. Life shoiuld be that fair, he's probably running the department. To find out if yours has them, you'll have to pull a wheel. Have you gone through the links that Rockledge posted? There's some nifty diagrams that you can compare to your setup.
Check https://www.ford-trucks.com/lc/lc.ph...iagnostics.pdf
You've got some diagnosing to do. Assuming of course that you do have the PVH. There's hords of threads pertaining to them. Try a search at the beginning of the forum.
Rockledge: Cute, I've actually never been quoted before. Especially since it was me quoting you. lol. https://www.ford-trucks.com/forums/s...68&postcount=6
Fred
Old Jun 12, 2007 | 03:30 PM
4LO 4.0's Avatar
4LO 4.0
if you find that you have the pvh system this might help.https://www.ford-trucks.com/article/...cuum_Hubs.html
Old Jun 12, 2007 | 07:10 PM
wendell borror's Avatar
wendell borror
You can do away with the pulse vacume hubs once and for all with a set of AVM manual hubs from Tellico 4x4. They sell for 105.00 bucks. AVM are the only ones that make manual hubs for the pulse vacume system.
lilbilli0naire
Oct 23, 2011 08:48 PM
bIIcool
Nov 18, 2008 01:44 PM
lola13
Feb 21, 2008 10:08 PM
dbrown13
Nov 13, 2006 06:17 PM
kds1973
Dec 17, 2004 12:37 PM
