Sponsored by: Real Truck
4x4 Engagment problems
Old Mar 14, 2005 | 02:14 PM
BIGTSV's Avatar
BIGTSV
My 4x4 F350 will not go into 4 wheel drive, the truck has the dash mounted switch and it will not engage the transfer case, any ideas of what is the problem????????Thanks in advance
Tom
Old Mar 14, 2005 | 03:02 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Mar 14, 2005 | 05:00 PM
Big Orn's Avatar
Big Orn
Welcome aboard, BIGTSV.
We'll need a little more info on your truck.
This is a fairly common problem with ESOF systems that don't get used regularly. The system seems to "hang up" if it's left idle for too long.
Have you went through the engagement sequences as outlined in your owners manual?
Can you hear a shifting sound where the transfer case is "trying" to engage?
How long have you owned the truck?
Old Mar 14, 2005 | 07:28 PM
BIGTSV's Avatar
BIGTSV
We have owned the truck for around 4 years now, it is a 1999
My father drives the truck almost all the time and he never puts it into 4wd,
I have went through the proper procedures as well. When we first got the truck it all worked and the last time I used the truck and went to put it in 4WD it acted as if the switch did not make at all, no sounds, clicks, grinds or anything.
I asked my dad if it had ever happened to him and he did say one time it took forever to get it out of 4 wheel low.
Is it the switch or actuaters???
Any info would be great!
Old Mar 14, 2005 | 07:35 PM
99f350sd's Avatar
99f350sd
Most likely its the hubs and or the shift motor on the transfer case..Its common as said above. Best to accuate 2 times a month or more.
Old Mar 15, 2005 | 08:26 AM
Big Orn's Avatar
Big Orn
Do a search here on "ESOF".
Get ready to copy and paste the different methods to get it to function again. Once you get it to where it will shift, then begin shifting often to ensure it will work each time.
Try this before changing parts and pieces. If it doesn't work, then you can feel confident that it's the servo (transfer case shift) motor or the switch.
Old Mar 15, 2005 | 10:47 AM
Lashlaroo's Avatar
Lashlaroo
My truck will not lock into 4x4 unless I'm moving. if I stop the front will not re-engage under 5 to 10 MPH??? Somthing with a centrifical clutch?? I must turn the hubs to lock If I want to get the boat out of the back yard. The dash switch alone will not lock the front end. down the road 4x4 in auto works great.
Old Mar 15, 2005 | 10:50 AM
99f350sd's Avatar
99f350sd
Everything should work just crawling if not your hubs are not engaging the way they should.
Dickl
Tom_Co
Jan 5, 2014 08:44 AM
Tom Callan
Mar 27, 2011 07:00 AM
tom1979
Mar 13, 2007 11:13 PM
FX4x4x4
2004 - 2008 F150
Aug 2, 2004 11:47 AM
