Flaring tool set ?
Old Dec 18, 2007 | 09:22 PM
RUSTY50F1's Avatar
RUSTY50F1
Flaring tool set ?
I need a double flaring tool set to do my brake lines and gas lines. Is GreatNeck / Double Flaring Tool Sae a good set to buy. Or not?
Old Dec 18, 2007 | 09:27 PM
ssj7kids's Avatar
ssj7kids
Rusty,
I bought one from Napa $70.00 and it was no good...
I bought a Rigid one and it worked great every time...
More than that I dunno.
Old Dec 18, 2007 | 11:35 PM
1952henry's Avatar
1952henry
I bought an old, old Imperial Brass set at a flea market--$10. Old school quality through and through.
Old Dec 18, 2007 | 11:51 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Rusty,
I bought a cheapo off the shelf at the local parts store. I can't remember the brand name but so far its worked out just fine. I did all the lbrake lines on my truck (some of them several times). I did tranny cooling lines as well. I even used it on the steel part of the power steering pressure line when I fabricated my power steering hoses.
The main thing is to use patience. Make sure your cuts are good and square, debur the ends of the lines (sometimes it helps to run a drill bit into the line after makeing a cut) Then make sure everything is nice and square when you clamp the flaring tool in place.
I own lots of expensive tools, most of them bought back in the day I turned a wrench and it was easier to buy from the tool trucks than take time off of work to go to the stores. I used to like Craftsman stuff but not anymore. I've actaully had real good luck with the Duralast tools that Autozone sells. Where ever you decide to get it from, see what kind of warranty they have on it.
Good luck with the lines (and remember to put the nuts on before flaring....lol)
Bobby
Old Dec 18, 2007 | 11:54 PM
kooper909's Avatar
kooper909
If you're using the Great Neck one anyway ... your local AutoZone should have it available for loan. You put down a deposit, take it home, use it, bring it back, and get your deposit back in full. Pretty sweet deal.
Old Dec 19, 2007 | 12:17 AM
lewislynn's Avatar
lewislynn
I don't know if you have a Pep Boys but I bought one there for $16, it worked great and it has a lifetime warranty...
If you're going use it often, I would look at a Ridgid or something like that
Old Dec 19, 2007 | 05:02 AM
mamelukesword's Avatar
mamelukesword
Patience
Bobbytm put it best, I bought a cheap set that worked great, you just have to ensure you don't get in hurry. I also found that some of the steel brake lines are lower quality, which effects flaring. I like the rental idea, if you only going to use it once it saves you a few bucks.
dennis
Old Dec 19, 2007 | 10:27 AM
RUSTY50F1's Avatar
RUSTY50F1
Thanks to all; Auto Zone is where I was going to buy the Greatneck, They will loan one out for $25 deposit. Get it back when you return it. But I have all the lines to do on my truck, plus I bought another project that will need all the lines done. And I found a 54 f100 that I am thinking about getting as well. The kid started on it got it half way dismantled and changed his mind. I can get it real cheap. Anyway I thought I'd just buy a new set for $25 so I'd have a set at home.
Old Dec 20, 2007 | 08:59 AM
thomc's Avatar
thomc
I have had several different ones over the years. All pretty much junk. Recently I found a good one at OReilly auto parts for 19.99. The brand is Performance Tools and part number is W80670.
Old Dec 20, 2007 | 12:36 PM
RUSTY50F1's Avatar
RUSTY50F1
Thanks thomc; There's one right down the street, I'll go look at it and see if it has a warranty with, it if so it will save me $10 on shipping.
Old Dec 20, 2007 | 01:50 PM
f100newb's Avatar
f100newb
Any one use the ones from Harbor Freight? I was looking at them there.
Old Dec 20, 2007 | 02:02 PM
RUSTY50F1's Avatar
RUSTY50F1
I looked at them also; I don't like the warranty at HF. I buy a lot of hand tools at HF, but not tools that I have to use on things that my life depends on. If you get my drift;
Old Dec 20, 2007 | 07:44 PM
angus's Avatar
angus
I bought a Lisle one for about $70, and just couldn't get it to make a proper flare; it looked like it had been machined wrong or something. A hydraulic shop was nice enough to lend me their tool (used the Lisle dies), and it worked fine: made one practice flare, then crawled under the van and did the brake line. (Rear section was badly rusted, front part was OK and difficult to reach to replace the whole thing.)
The good tool was a Ridgid #345. The same tool is sold under some other brand names; I found a complete kit used with the double flare adapters. It came in handy for making new lines for the '57 panel truck, as well as fixing a neighbour's "garden truck" (wasn't licensed for the road).
Old Dec 20, 2007 | 10:40 PM
OilLeaks's Avatar
OilLeaks
AutoZone is a good way to go if you just need to make a couple of flares. If you are a tool junkie (and most of us are if we're honest) then you can't go wrong with a Rigid tool. That's what I bought and I've been very happy with it.
OilLeaks
broke33
Mar 24, 2005 01:27 PM
JerseysBest
Garage & Workshop
Dec 1, 2004 05:55 PM
jniolon
Jul 13, 2003 06:36 PM
Geffrey Travis
Oct 12, 1999 07:56 AM
