I bought a cheapo off the shelf at the local parts store. I can't remember the brand name but so far its worked out just fine. I did all the lbrake lines on my truck (some of them several times). I did tranny cooling lines as well. I even used it on the steel part of the power steering pressure line when I fabricated my power steering hoses.
The main thing is to use patience. Make sure your cuts are good and square, debur the ends of the lines (sometimes it helps to run a drill bit into the line after makeing a cut) Then make sure everything is nice and square when you clamp the flaring tool in place.
I own lots of expensive tools, most of them bought back in the day I turned a wrench and it was easier to buy from the tool trucks than take time off of work to go to the stores. I used to like Craftsman stuff but not anymore. I've actaully had real good luck with the Duralast tools that Autozone sells. Where ever you decide to get it from, see what kind of warranty they have on it.
Good luck with the lines (and remember to put the nuts on before flaring....lol)
Bobby
If you're using the Great Neck one anyway ... your local AutoZone should have it available for loan. You put down a deposit, take it home, use it, bring it back, and get your deposit back in full. Pretty sweet deal.
Bobbytm put it best, I bought a cheap set that worked great, you just have to ensure you don't get in hurry. I also found that some of the steel brake lines are lower quality, which effects flaring. I like the rental idea, if you only going to use it once it saves you a few bucks.
Thanks to all; Auto Zone is where I was going to buy the Greatneck, They will loan one out for $25 deposit. Get it back when you return it. But I have all the lines to do on my truck, plus I bought another project that will need all the lines done. And I found a 54 f100 that I am thinking about getting as well. The kid started on it got it half way dismantled and changed his mind. I can get it real cheap. Anyway I thought I'd just buy a new set for $25 so I'd have a set at home.
I have had several different ones over the years. All pretty much junk. Recently I found a good one at OReilly auto parts for 19.99. The brand is Performance Tools and part number is W80670.
I looked at them also; I don't like the warranty at HF. I buy a lot of hand tools at HF, but not tools that I have to use on things that my life depends on. If you get my drift;
I bought a Lisle one for about $70, and just couldn't get it to make a proper flare; it looked like it had been machined wrong or something. A hydraulic shop was nice enough to lend me their tool (used the Lisle dies), and it worked fine: made one practice flare, then crawled under the van and did the brake line. (Rear section was badly rusted, front part was OK and difficult to reach to replace the whole thing.)
The good tool was a Ridgid #345. The same tool is sold under some other brand names; I found a complete kit used with the double flare adapters. It came in handy for making new lines for the '57 panel truck, as well as fixing a neighbour's "garden truck" (wasn't licensed for the road).
AutoZone is a good way to go if you just need to make a couple of flares. If you are a tool junkie (and most of us are if we're honest) then you can't go wrong with a Rigid tool. That's what I bought and I've been very happy with it.
