remote start install manual
Old Dec 15, 2007 | 08:53 PM
  #46
rotun's Avatar
rotun
Reads ***** rules!
Canadian.......just sent veh. specific as well as the gold pack. gen 2 install instructions. Let me know if you want the relay wiring for the idle up. rr. defrost.
Kyle.......just sent you the bronze pack install instructions.
Derek
Old Dec 16, 2007 | 12:08 AM
  #47
Canadian 6.0's Avatar
Canadian 6.0
thanks. If I could get teh idle up/defrost instructions would be great also.
thanks again.
Old Dec 19, 2007 | 12:01 PM
  #48
rotun's Avatar
rotun
Reads ***** rules!
O.K. sorry took so long. Here's the pin out info for wiring the idle up to the Gen2 Gold Package rear defrost output.
on the relay:
pin 30 to PTO Orange wire
pin 85 to gold module rear defrost output (blue/white coming off module)
pin 86&87 to 12v (white/blue) on truck above the accelerator pedal.
you can still run the idle up off of a toggle switch for manual on/off, I used the white/blue above pedal and ran through a toggle switch to the PTO orange wire. Tap pin 30 AFTER the toggle switch.
Once hooked up, remote start the truck, then hit the start button on the fob to activate hi idle, hit start button again to kill hi idle or hold start button to shut off engine. Using the rear defrost output from the module will only allow the hi idle to run (remotely) for no more then 20 minutes.
Old Dec 21, 2007 | 12:19 PM
  #49
hanley111's Avatar
hanley111
Can you please send the instructions for the remote start to me @ cadendadd@charter.net
Regards
Cad
Old Dec 21, 2007 | 01:06 PM
  #50
rotun's Avatar
rotun
Reads ***** rules!
Regards
Cad
As stated earlier in the thread.............I will need to know year/model of vehicle as well as which model system you have.
treatcg
6.7L Power Stroke Diesel
Dec 13, 2016 10:57 AM
chiefk
1983 - 2012 Ranger & B-Series
Sep 24, 2016 08:03 AM
bobv60
Nov 25, 2015 10:33 AM
Curt's05
Apr 1, 2015 11:49 AM
Ford Fx4
2004 - 2008 F150
Nov 18, 2007 08:51 PM
