Hood release cable broken
Old Nov 30, 2007 | 08:57 AM
hunter1897's Avatar
hunter1897
How can you open the hood of a 1988 F150/Bronco if the hood release cable is broken?
Old Nov 30, 2007 | 09:02 AM
superduty4x4's Avatar
superduty4x4
Never tried it on my personal truck, but on my work truck (05 Chevy- hey I didn't have a choice in the matter) I was able to use a long screwdriver through the grill to pop the hood latch open.
Old Nov 30, 2007 | 09:03 AM
tomtoc's Avatar
tomtoc
side note: also make sure you never accidentally close/lock the latch while the hood is up. it was a pain to pop back open
Old Nov 30, 2007 | 12:58 PM
jas88's Avatar
jas88
Take out the grille and then you will be able to easily get to the latch with a screwdriver.
Old Nov 30, 2007 | 01:39 PM
Skandocious's Avatar
Skandocious
Jas is it possible to remove the grill without popping the hood?
If this happens, and your hook latch cable still works, just pull the hood release again ya' dummy
Old Nov 30, 2007 | 01:42 PM
tomtoc's Avatar
tomtoc
my thoughts exactly
tried that, i swear. right after i did it, i saw a thread on it too, so i'm not the only one. i think it i had to use a screwdriver and pull the cable at the same time or something goofy. all i remember - it was a pain
Old Nov 30, 2007 | 01:58 PM
Skandocious
Well I did that once with my truck Tom and I just pulled the hood release in the cab... Worked fine for me...
Old Nov 30, 2007 | 02:06 PM
danr1's Avatar
danr1
You may be able to grab the cable itself through the grill and pull on it, if the inner cable is broke the outer casing will slide off of it, then pull on the inner cable to open the hood.
You may have to push the outer cable end free of the bracket right next to the latch itself so it will slide off the inner cable so you can grab it. The end of the outer cable sits in a slot in that bracket, pushing it back toward the motor and slightly up should do it.
Old Nov 30, 2007 | 02:09 PM
danr1's Avatar
danr1
If you can't get it post back and I'll walk out back and open the hood on my 87 and see exactly what it will take to do it. (I can open the hood for a closer look)
Old Nov 30, 2007 | 02:58 PM
superduty4x4
Good luck removing the grille with the hood shut. That's why the long screwdriver is key
Old Nov 30, 2007 | 04:45 PM
jas88's Avatar
jas88
Good luck removing the grille with the hood shut. That's why the long screwdriver is key.
I noticed that everybody who questioned my post here owns 92-96 trucks. Maybe this is true for your trucks, but not for ours. Note he has an 88. I have a 91. The only thing under the hood that is holding the grille is a few of those little plastic clips with the plastic screws that wedge inside, if they are even still there. Release the grille clips (big plastic ones, 2 each side, inside the grille) and pull the bottom of the grille out and then pull down. It will pull right out of those little plastic screw things.
The answer to your next question is yes I have done this myself.
Old Nov 30, 2007 | 05:29 PM
Skandocious
So what you're saying is... If I never need an 80s Fseries grill I can steal someone elses VERY easily
Old Dec 1, 2007 | 08:04 AM
hunter1897's Avatar
hunter1897
I had thought about trying to remove the grill. I noticed that there are supposed to be 4 black push pin plastic screw things (they have a phillips head on them, but don't really screw out) holding the grill from the front. 3 of mine are missing, so I think I'll pop the 4th one out then do as you said and try to pull the grill out and down. I assumed there must be something holding it in under the hood, but didn't want to break it, but I'll give it a try because I just can't get my hand in there far enough to grab the cable and pull it out to pop the hood with the grill in. Will let you know how it goes.
Old Dec 2, 2007 | 05:17 PM
hunter1897's Avatar
hunter1897
I removed the remaining forward facing push pin and was able to pull the grill out a bit and down, but since I have a plow on the truck I didn't have much room and couldn't get it actually out of there. But I got it down enough so the I could slip a hack saw blade in and cut each of the top mounted push pins in half one at a time. It worked enough that I got the cable and was able to pull it and open the hood. Thanks all.
Old Dec 2, 2007 | 06:00 PM
Slow96's Avatar
Slow96
No no no no, it doesn't work like that, haha. I had to reach through the grill, and unbolt the hood latch. My wrists looked like I had been cutting them for years, since the back of the grill is suprisingly sharp! I will NEVER make that mistake again, it only took once for me to learn that one.
hhight
WTB - Parts & other
Nov 8, 2014 07:13 AM
GEugeneS
Sep 22, 2013 11:35 AM
Michael Pace
Jun 24, 2013 11:53 AM
jayman1958
Jul 12, 2010 11:03 AM
chadwj
Jun 27, 2007 11:53 AM
