Rusty floor pan. HELP
Old Nov 9, 2007 | 10:08 PM
jimlj's Avatar
jimlj
I removed the floor mat from the back area of my super cab and found what looks like some bad swiss cheese. Other than replacing the floor or entire cab, what are my options? I'm not after a 1st place show winner, but I want a nice looking truck when I'm done. I don't live in the rust belt, but the previous owner may have.
Old Nov 11, 2007 | 12:28 AM
Dana Jensen's Avatar
Dana Jensen
I working on a trunk floor right now like that. I'm covering the existing swiss cheese metal with fiberglass. Seems to be working so far. I don't know how this would work on a truck floor but it might be worth a try. Doesn't cost much.
Old Nov 11, 2007 | 09:11 AM
blue68f100's Avatar
blue68f100
You can buy patch panels for the floor. Since you just want it fixed and don't care hows it look. just lay it on top of the original one and weld it in. Then seal it up with POR15 or any other rust encapulator. If you don't have a welder, 3M make an adhesive for gluing in panels. Was shown on Trucks TV program.
Old Nov 12, 2007 | 01:34 PM
fastmover's Avatar
fastmover
Will the 3m adhesive work for floor panels that will have a good bit of weight on them (feet, seat, and other stuff)?
Old Nov 12, 2007 | 01:43 PM
khadma's Avatar
khadma
Carpenter Local 745
3m has that double sided tape with the (red film to keep it from sticking to itself) I forget the name, but it is stronger that the two surfaces that need to be bonded. Very expensive.
Old Nov 12, 2007 | 01:52 PM
blue68f100's Avatar
blue68f100
The panel fits inside the cab, so you have the remaining floor pan to support it. But if its's really bad, no good metal to ahdere to or to support the pan, NO.
Old Nov 12, 2007 | 01:58 PM
khadma's Avatar
khadma
Carpenter Local 745
http://solutions.3m.com/wps/portal/3...l-Fabrication/
If you still have floorpan to attach to.
Get replacement pans and cut out just the bad sections. Find someone with a welder to help you get the new pieces welded in.
Old Nov 12, 2007 | 02:02 PM
khadma's Avatar
khadma
Carpenter Local 745
which truck? what year?
emgee
Jul 18, 2014 08:50 PM
southtexasidi
Apr 7, 2014 07:34 PM
crazed87bronco
17
Nov 8, 2010 10:31 AM
76CamperSpecial
Aug 7, 2008 08:45 AM
Sarge513
Jun 4, 2007 06:05 AM
