Injector Lube
Old Nov 7, 2007 | 08:36 PM
2 stroke man's Avatar
2 stroke man
i've used tranny fluid (more smoke), howe's ten point (good stuff), total power(the stuff), and diesel kleen (good stuff). tranny fluid is cheaper, but ATF WILL SETTLE IN BOTTOM OF TANK IF NOT DRIVEN ALOT, and, i like the smoke. total power has stabilizer, anti gel, +8 cetane, lube, cleaner, all that good stuff, as do the others, but i get better mileage with my total power.
Old Nov 7, 2007 | 08:39 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by PAVEMENTMAN
Whats A Good Additive To Run In My Fuel For Lubing The Injectors. I Heard Tranny Fluid Is Good Is This True.
Transmission fluid is effective at cleaning injectors, but it makes a lousy lubricant. I use Lucas upper cylinder treatment as long as it's above freezing. Below freezing I use Howe's diesel fuel conditioner. I'll use Power Service in a pinch, but I don't care for it at it kills my fuel economy.
Old Nov 7, 2007 | 09:22 PM
powerstrokeddiesel's Avatar
powerstrokeddiesel
does atf increase black smoke???
Old Nov 7, 2007 | 09:25 PM
tjbeggs's Avatar
tjbeggs
Yeah it increase smoke! when it destroys your injectors!!!
Old Nov 7, 2007 | 09:28 PM
powerstrokeddiesel
is the smoke black or blue???
Old Nov 7, 2007 | 09:34 PM
tjbeggs's Avatar
tjbeggs
Its red..... No really I don't know. I would never put the stuff in my truck to find out.
Old Nov 7, 2007 | 09:36 PM
powerstrokeddiesel
if it was red i would deff burn it...
Old Nov 8, 2007 | 05:56 AM
bkcowboss's Avatar
bkcowboss
here is a study that was done on just the lubricating properties of different additives. They unfortunately did not include ATF. I found it interesting because lucas upper cylinder lubricant, does nothing for lubrication, diesel kleen is negligable, 2 stroke oil, which I ran for a while lubricates well, and worked good for me, but it has no other properties besides lubrication I am going with optilube XPD. But like several above said biodiesel, better than 2% is the best.
here is the link where I got the info
https://www.ford-trucks.com/forums/6...additives.html
brandon.edwards
Mar 30, 2014 02:48 PM
silly34
Jul 26, 2009 08:41 AM
Ford Truck Racer
Sep 30, 2002 10:20 AM
rebocardo
Aug 18, 2002 09:24 PM
FTE Ken
Jan 2, 2002 04:16 PM
