exhaust leak
exhaust leak
Yes you could have a leak from a lot of places. Can you have a friend look underneath while you stick your foot on the tailpipe to plug it for a few seconds. My bet is that if it is not the muffler or a pipe than it will likely be the oxygen pipe which leads up to the back of the head from the catalytic convertor.
exhaust leak
>These 4.9L are natorious for a exhaust manifold leak...might
>wanna look into that. The manifolds will warp and cause a
>ticking noise if thats what it is.
thats good to know because my truck has a slight tick to it and i cant seem to trace it down in the exhaust, ill look into to, thanx
exhaust leak
i have a leak too and im looking into using the split manifolds. What bolts do i use to bolt them and my offy intake maifold to the block? also if i install strait manifolds and no exchaust and drive it to the muffler shop, can they make a y pipe and everything i need to set up the exchaust or do i have to buy somethign else?
BIGRED-Fordzilla
10-08-2014 11:23 PM
ArmyAviator
1983 - 2012 Ranger & B-Series
12-08-2007 05:55 PM
ericas46
11-16-2004 05:13 PM
