1996 Ford Explorer leaking coolant
Old Nov 14, 2004 | 05:25 PM
ericas46's Avatar
ericas46
Question 1996 Ford Explorer leaking coolant
I have a 1996 Ford Explorer V6 4.0L with 109,000 miles. I have been experiencing coolant leaking when the heat is on. I noticed it is coming from at/near/around the heater hoses. But the heat works fine and when I turn it off, the leaking stops. What could this be?
Erica
Old Nov 15, 2004 | 11:19 AM
Pikachu's Avatar
Pikachu
Any fogging of the windows or coolant smell in the cab? If yes, suspect bad heater core. If no, check hose clamps/hoses.
Old Nov 15, 2004 | 11:30 PM
ericas46's Avatar
ericas46
No, there is no smell of coolant and no fogging. The hoses running to the interior are fine but there is a part that is connected off of the hoses. That is what is leaking, but I do not know what the name of that part is. Thanks.
Old Nov 16, 2004 | 05:13 PM
Pikachu's Avatar
Pikachu
Ahhhh.... That is probably a vacuum solenoid that controls the water flow to the heater core. If that is what is leaking, NAPA should carry those. If not, even a dealer shouldn't be all that expensive.
RMD89
New Member Introductions
Feb 3, 2016 02:42 PM
mort6860
Jun 5, 2015 11:40 AM
Erica V. Goodwin
Oct 23, 2014 05:32 PM
erica
Aug 2, 2014 07:16 AM
donhclark
May 23, 2003 01:11 PM
