P0141 1996 Ranger 2.3L Automatic
Old Mar 3, 2013 | 08:07 AM
Rags1996's Avatar
Rags1996
Hi everyone,
I need your help once again for upcoming vehicle inspection. My 1996 Ranger runs ok but my check engine has come on. Using a scanner tool , indicates my cat monitor wont go to ready state and my error code is P0141. According to my research it indicates one of my 02 sensors. Does anyone know how to determine if its the one before or after the cat converter? About 6 months ago I had an exhaust leak repaired around my converter so I know I cant return it under warranty . If its the rear sensor , It looks fairly easy to replace but the front sensor looks a bit cramped. Any help would be greatly appreciated ! And thanks for reading.
Old Mar 3, 2013 | 09:31 AM
Rockledge's Avatar
Rockledge
DTC P0141 = HO2S HTR-12
That code implicates the O2 sensor downstream (after) the cat.
If there are two cats, then it would be the passenger side downstream 02 sensor.
Be sure to check the wiring and connection while you are under there. And check any related fuses.
Old Mar 3, 2013 | 12:46 PM
Rags1996's Avatar
Rags1996
Thanks! I was hoping it was that 2nd sensor . Good idea to chech the fuses too. I had trouble in the past with good fuses but corroded fuse sockets making them seem bad.
Old Dec 27, 2013 | 07:45 AM
kdwellsr's Avatar
kdwellsr
I have a 98 f250 with P0141 code. I believe its the one downstream but how do I know if its the drivers side or passenger side? The reader didn't specify. It just says Sensor Heater Circuit.
Old Dec 27, 2013 | 09:49 AM
Rockledge's Avatar
Rockledge
Passenger side.
Old Dec 28, 2013 | 10:23 AM
tomw's Avatar
tomw
The code indicates either '1' or '2', with the former being on the right side bank looking from the flywheel forward. Number 2 would be the left bank. The second digit says up stream or down stream sensor. 11 would be right/passenger upstream. 21 would be drivers/left upstream.
tom
Old Dec 28, 2013 | 04:30 PM
kdwellsr's Avatar
kdwellsr
Thank you. Thats what I was curious about.
CMOS
2009 - 2014 F150
May 5, 2020 07:52 PM
rangergolfer
Dec 16, 2011 02:36 PM
poseidon
1997 - 2003 F150
May 29, 2010 04:11 PM
Blue'87GT
1978 - 1996 Big Bronco
24
Nov 20, 2004 10:30 PM
stupid red ranger
Jan 28, 2004 11:21 PM
